Best intake for 07 335i?
08-01-2010, 09:08 PM | #1 |
67
Rep 3,214
Drives: f25 X3 AW
Garage List 2004 e46 M3 AW RETIRED [0.00]
2003 e46 M3 CB RETIRED [0.00] 2013 f25 X3 AW [0.00] 2007 e92 328i SG RE ... [0.00] 2007 e90 335i AW RE ... [0.00] |
Cant decide which intake to get for my 335i, had it for a few months and am starting to build it up. Let me know what you think. thanks
M |
08-02-2010, 12:56 AM | #4 |
46
Rep 1,681
Define best. Its subjective. What're you looking for? How much are you willing to spend?
2006 JB 330i/ZPP/ZSP/I-Drive/Heated Seats/L7/Blacklines/19" Gunmetal V710's on Vredestein Ultrac Sessantas/BMS PBX/Red MFD Scoops/Matte black grilles/Matte black Amber Gone 2.0s/BSW center midrange speaker/35% tint/Black and white roundels
08-02-2010, 01:03 AM | #5 |
38
Rep 185
i dont have but 2 of my friends do and it sounds amazing and they love it http://www.burgertuning.com/dcintake.html
08-02-2010, 09:02 AM | #7 |
184
Rep 7,269
Drives: 2009 335i X-Drive
performance wise won't notice...but injen DCI for the looks and BMS for the price
08-02-2010, 02:17 PM | #10 |
37
Rep 2,084
I'm guessing you didn't really mean best. But if you did, list price on the Dinan is $1000. The 20% discount I got is probably not available anymore.
08-02-2010, 02:28 PM | #11 | |
30
Rep 1,748
Are you running a tune? Answer #1 IF so: -BMW stock intake is good until around 375hp (Try putting in a replacement filter from K&N, AFE or one of the other manufacturers) -BMS DCI (Dual cone intake) is a cheap way to get your DCI fix -INJEN DCI is an expensive way to get your DCI fix, but it also looks very clean in the engine bay (I had this when i had my 335xi) -AFE, not as expensive as the INJEN, but I don't think it' looks nice in the engine bay. -You may want to consider a Cold Air Intake from STETT or UR, check the threads formely_boosted_is has posted on this Answer #2 If Your not running a tune, don't even bother looking at an intake. More than likely if you get an intake, and your not running a tune you are going to loose HP/Torque, and then you just wasted anywhere from 120-300 that you could have spent on a tune that will give you more HP/Torque than an intake will ever give you. Answer #3 is your friend, because their have been numerous threads on this subject, and if you did search, you wouldn't have opened a new thread on the same subject...
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
08-02-2010, 02:36 PM | #12 |
29
Rep 174
+1. Any intake that grabs the air from inside the engine bay is not going to be as good as one like Dinan that has the intake running down behind the bumper to grab cool air from outside the car.
08-02-2010, 03:42 PM | #13 |
177
Rep 1,105
The stock intake is best. The paper filters flow just as good (unless you're running a ton of additional boost), it gets cool air from in front of the radiator, and the filtration ability of paper is WAY, WAY better, and they take MUCH longer to clog up (so after ~5-10k miles, you're flowing much BETTER with a paper filter).
Gauze filters typically flow slightly better (until dirty, and we're talking a hard to measure pressure drop improvement), yet typically have a much smaller surface area (fewer, shallower pleats). This necessarily means the pores are MUCH bigger, allowing more junk into your engine with little to no performance gain. A big dual-cone filter might have as much surface area as the paper filter, but will be injesting hot air, and will just let grit into your engine for longer before it clogs up. What you will get from a cone intake is a cool "whoosh!" sound from the turbos. Other than that, an intake on your stock car is all negatives. BMW knew what it was doing when it designed the intake. |
08-02-2010, 03:59 PM | #14 |
I ask the questions you're afraid to ask.
44
Rep 2,489
Except of course that the air at bumper level is pretty hot since the heat is reflected off the asphalt.
08-02-2010, 04:01 PM | #15 | |
44
Rep 2,489
Also, people fail to understand that the only way to get more airflow is to use a more porous filter - allowing more crap into the engine. |
08-02-2010, 08:25 PM | #17 | |
Rep 53
so what are your opinions about which tune to go with if one is scared about warranty?
2007 CPO 335i Sedan / Arctic Metallic / Black Dakota Leather / Aluminum Trim / 6MT / Navigation / Sport / Premium / iPod Link
pics: http://www.e90post.com/forums/showthread.php?t=415615 |
08-03-2010, 11:09 AM | #19 | |
30
Rep 1,748
IF you want no warranty issues, Dinan Flash IF your a DIY, go with PROcede with it's Autotune and Built in Code Clearing Function, or JB3 & a BT tool. BT tool is a good thing to have even if you don't tune, it can help you diagnose any issues you are having with the car. There are a crap load of other tunes out there, just and you'll find out everything you want, or need to know..
