Trying to install an amp and sub
07-24-2010, 11:17 AM | #1 |
Rep 8
Hello everyone
I tried to do a search on the forum but I didn't come across the diagram that I am looking for. Does anyone have a diagram or a list of the wires for the factory amp on an 08 328i? I need to know which wires are for the rear speakers and which wire is the remote wire so I can hook up my amp and sub. I believe that I have the basic system, not the logic 7. How can I be sure of this? Here is what I'm looking at: Sorry about the picture quality but my camera battery is dead so this is from my phone. |
07-24-2010, 11:50 AM | #2 | |
2306
Rep 13,011
Pin 13 Mid Rear Right +1 2 3 Woofer Left - 4 Woofer Left + 5 12V 6 7 8 Rear Right Output + 9 Front Right Output + 10 Remote IN 11 Mid Front Right + 12 Mid Front Right - 14 15 16 Rear Right Output - 17 Front Right Output - 18 19 20 21 Mid Rear Right - 22 Woofer Right -23 Woofer Right + 24 25 26 Ground27 28 29 Rear Left Output - 30 Front Left Output - 31 Mid Rear Left + 32 Mid Rear Left - 33 Mid Front Left + 34 Mid Front Left - 35 36 37 Rear Left Output + 38 Front Left Output + 39 40 41 42 Outputs are balanced signals so you need to use a balance signal-compatible sub amp (i.e. JL Audio) if you want to connect these outputs directly to that sub amp. If not then you will need a balanced to non-balanced converter before that sub amp. |
07-24-2010, 12:31 PM | #3 |
Rep 8
Thanks! I am using this: http://www.bestbuy.com/site/Axxess+-...xess&cp=1&lp=3
Which speakers should I be tapping into? Rear woofers or regular rear output? What's the difference? I only have rear speakers above my seats, I don't think I have seperate subs. How do I check? Thanks for the help. |
07-24-2010, 01:08 PM | #4 | |
2306
Rep 13,011
What amp are you using for this? |
07-24-2010, 01:35 PM | #5 |
1918
Rep 13,117
Look at this link.
http://www.e90post.com/forums/showthread.php?t=52193
be sure to look at all 3 pages for block diagrams and pictures |
07-24-2010, 02:01 PM | #6 | |
Rep 8
07-28-2010, 07:26 PM | #7 |
Rep 8
Ok, so I ended up buying a new amp online and I just got it today. I went to wire up everything using the diagram but my harness is different. I have no wire going into pin 16 and no wire in 37 so I couldn't use my rear outputs. I didn't try using different outputs because I'm not sure if my oem system has completely different wiring. I don't want to end up tapping into the wrong wires.
07-28-2010, 07:45 PM | #8 | |
2306
Rep 13,011
07-28-2010, 08:18 PM | #9 |
Rep 8
I have the same connector. The pin numbers are correct however there are no wires in those pins. Also, for pin 8, I just have a small solid black wire instead of a speaker wire. I'm really confused now. How do I know what sound sysem my car has?
07-28-2010, 08:48 PM | #10 | |
2306
Rep 13,011
You should be able to even see the metal female pins thru holes 16 and 37 like in that photo. I did several weeks ago a full system in a MY2010 E93 M3 with the HiFi and both the pin assignments and the schematic are correct for this connector. There's no way that you are missing those wires. Is this an used car? |
07-29-2010, 01:25 PM | #11 |
Rep 8
I bought the car used but it is fully oem. The harness still had the factory wrapping and everything. I will take a pic of the harness later today when I'm home and post it. The wires are definately not there. I double checked this morning before I left.
07-29-2010, 01:48 PM | #12 | |
2306
Rep 13,011
07-29-2010, 07:20 PM | #13 |
Rep 8
Here is a pic of the backs of the connectors:
My wiring is completely different. If the color code is the same for all e90's, maybe you can tell me the colors for the rear outputs and the remote wire. Thanks for the help |
07-29-2010, 07:54 PM | #14 | |
2306
Rep 13,011
