9.5" Front????
07-24-2010, 01:34 AM | #2 |
310
Rep 15,745
Possibility of rubbing the strut, and usually rubbing the fender liner on full steering wheel lock.
9.5 is tough to fit in the front. Offset has to be on the money. My gf runs 19x10 +22, the wheel misses the strut housing by hairs and the lip sticks out beyond the fender. It's really aggressive, plan on stretching tires to make it fit. |
07-24-2010, 10:34 AM | #3 |
Rep 69
+1
335i | ZSP | 6MT |bmw short shifter| DIANAN STG.II w/JB4 |Quaife-3.46|AMS intercooler|BT OCC|AR Oil cooler|Forge dv's| Injen Intake |AR catless DP'S| AE dual catless exhaust|Bilstein PSS10's | M3 suspension bits | 19" Volk TE37 Toyko Time Attacks|
07-24-2010, 02:13 PM | #4 |
89
Rep 3,355
Drives: VIP Sport 335!
19x9 is good for the front.
07 E92 335!
AA AE GP HR LC M3 KW BMS BMW LUX CYBA STRI WORK HELIX MTECH LSWEEE(Wavetrac)! |
07-24-2010, 09:24 PM | #5 |
141
Rep 1,423
Drives: '07 N54 e90, '10 N54 e93, TBSS
07-26-2010, 11:52 AM | #6 |
BimmerPost Supporting Vendor
2040
Rep 25,989
9.5" fronts can work but may require modifications if you plan on lowering the vehicle. We have tested a 9.5 +33 front with a 235/35/19 tire with zero issues at stock ride height.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
07-26-2010, 08:34 PM | #8 |
Ground Clearance?
232
Rep 1,651
et in the 30's. mine was 33 without spacers. will not rub with a 235 or a 225. will not hit the strut, the fenderliner. or anything. you'll be fine, even lowered 2.5 inches
E90 330i - E90 335i - E92 335i |
07-26-2010, 08:39 PM | #9 | |
81
Rep 4,541
08-01-2010, 07:00 PM | #11 | |
Rep 26
Thats good to know! But what if u lower the car with KW variant2 coil overs?? But not too low. Just to get rid of the space between the wheel well and the tire. Do you need any mods with that?? |
08-02-2010, 12:22 PM | #13 | |
1767
Rep 7,652
Anytime you do such a set up, the proper way to do it is to do a full alignment and tweak them to make sure that everything fits without issues. you will also need to make sure that all four corners have the ride height adjusted at the same time. This is not going to be an easy cookie cutter method but with proper installation and alignment, you'd be riding them with no problems. recommend the KW V2 install first, let it ride for a few hundred miles, install the wheels and then do a full alignment and proper height adjustment. Also, most of the time, you won't need to go out of stock parameters on your alignment but in some cases you may need to do so... slightly. This is where it becomes an art form.... pull it off right and it looks real good.
08-02-2010, 12:41 PM | #14 | |
2040
Rep 25,989
-Charles@VMRWheels
08-03-2010, 06:29 PM | #15 | |
Rep 26
Thanks for the info man! I just want to make sure that I dont need to roll my fenders when I run 10" rear and 9.5" front. |
08-03-2010, 06:36 PM | #16 | |
Rep 26
I just want a decent drop. Not too low like the H&R sport springs. I want to run 10" rear and 9.5" front. You think its gonna work without rolling the fenders? |
08-03-2010, 07:13 PM | #18 |
99
Rep 443
Its good to see our fellow E90 guys venture into the 9.5 fronts.
As Julius mentioned, I would get the coil overs first and let every settle before fitting wheels. Here is Mark Arcenal from Fatlace's 328Xi on KW Variant 2/VMR V701's 19x9.5 +22 - 235/35 , No roll needed at all! 19x9.5 +7 255/35 , small sidewall tire, rolled rear fender |
03-06-2016, 06:44 PM | #21 |
Rep 2
I have a 2013 BMW 335i Coupe M-Sport.
I am running 19x9.5 et33 front and 19x10.5 et 38 rear. Tires are Federal 595s 245/35R19 and 275/30R19. No rubbing at all turning or taking bumps. I don't plan to lower. I want comfort and ride quality. No rolling fenders needed with this combo. Last edited by Broqsten; 03-06-2016 at 08:52 PM.. |
03-06-2016, 08:45 PM | #22 |
Rep 2
