Structural rigidity of e93
07-21-2010, 11:17 AM | #1 |
32
Rep 480
My question is about the strength of the roof on the e93.
When you drive on bumpy roads with the window down and your hand on the joint between the roof and the a pillar, you can feel a wiggle which wouldn't be there in the case of a sedan or couple. How can this be improved, if at all? How much of the weight of the roof weight is in the arms and are they steel, iron, alum; how much of the weight is in the top panel, rear panel, back window? I figure that the A pillars of the e93 are stiffer than those of the coupe or sedan for a few reasons, but in the event of a roll-over with the top up, do the C pillars hold up well? I know the Rear seats have integrated roll bars which probably do not fire with the roof up(?). How does the joint between the front and rear panel hold up? Last edited by TotalPower; 07-21-2010 at 11:36 AM.. |
07-21-2010, 11:28 AM | #2 |
363
Rep 5,873
Drives: m
I have no idea but I can only imagine their must be some safety standard in the event of the roll. But then I think of the ford explorer or whatever that had a paper like roof that collapsed on a few people.
07-21-2010, 11:41 AM | #3 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
This is common with most "wagons".
Try rear strut braces at the c-pilar. Look for something like this:
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
07-21-2010, 03:38 PM | #4 |
Where'd my VTEC go?
481
Rep 6,067
The roof on the E93 is not designed to support the car. Rollover bars behind the rear headrests will pop up in the event of a rollover to support the car.
07-21-2010, 04:23 PM | #5 |
1121
Rep 5,396
I apologize! I thought you guys were talking about wagons, but apparently, you are talking about convertables.
07-21-2010, 05:15 PM | #6 |
32
Rep 480
07-21-2010, 05:32 PM | #8 | |
923
Rep 15,818
Also, I don't feel anything like that at all
