2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY Oil Change F10 5-series (N55 motor)
      07-20-2010, 08:39 PM   #1
gatoman39
gatoman39's Avatar
116
Drives: 2011 E92 335 M-Sport
1100 miles, time for a oil change.
Parts:
  • Fully Synthetic Oil 7 Quarts BMW High Performance Full Synthetic 5W30* (BMW P/N: 07 51 0 017 866), Mobil 1 0W40, or Castrol Syntec European Formula 0W30.
  • Oil Filter (BMW P/N: 11 42 7 566 327) - Comes with 2 o-ring washers (1 big black, 1 small green), and 1 copper crush washer.
  • Oil Filter Wrench, there are several on the market. I used my hand but this might be too hard for you paper pushers.
  • Floor Jack (I used 2) with jack stands
  • Oil Drain Pan.
  • 17 mm socket (1/2" drive wrench).
  • Torque Wrench
  • Rags / paper towels.
  • Disposable rubber gloves.
  • Funnel.
  • Needle nose pliers.
  • Goggles.
  • Beer for after.
Make sure oil is at operating temp before doing this.
1. On a level surface, engage parking brake and chock rear wheels
2. Lift front of car, I used two floor jacks with plastic pads to keep from damaging plastic jack points on the F10.
3. Use jacks stands in case floor jacks malfunction (this is VERY IMPORTANT) Never get under a car without proper safety backup.
4. Remove small bolt that holds trap door in place, remove trap door.
5. Using 17mm socket and wrench loosen drain plug. (Bolt faces down, so no mess with angle draining)
6. Lower car back down to ensure even oil draining. This will take a while, I made a sandwich during the time.
7. Remove oil filter, I did it by hand but if your kung fu grip isn't strong enough buy the filter wrench. With needle nose pliers remove green gasket and large black gasket on oil filter housing. Pull oil filter out. Install new filter, the writing was facing out or down. Put new gaskets on the filter housing. I soaked the new filter in a little oil and rubbed some oil on the new gaskets. I sucked out all the residual oil in the filter seat with a turkey baster. Screw filter back into the base. Match the green alignment marks (thanks for that Dingolfing!)
8. Jack Car back up, place jacks stands in position again, make sure the rear chocks haven't moved around. Put copper crush washer onto new bolt, put a little oil on the threads of the bolt, and tighten bolt back by hand at first then use the 17mm socket and torque the bolt back to 25-30lbs/ft, don't over tighten.
9. Put trap door back in place (or leave open to check for leaks later, I skipped this as I am confident in my DIY skills, if you're not, triple check everything).
10. Place car back on level ground, and fill with 7 qts of oil. I list the 3 grades and brands above because they are the most common in N. America and can be found easily, don't send me PM's about how great Amsoil or Redline is, most people don't want to deal with the hassle of getting that stuff.
11. Drive car around until oil level appears on IDrive (this took forever, and pissed me off. My kingdom for a dipstick!!!)
12. Bask in your glory by consuming beer or adult beverage of choice.
chock rear wheels
I used two floor jacks with plastic pads to keep from damaging plastic jack points on the F103.
Early and often for the first year. I own this car, it's not rented.:
Planned schedule:
Total Vehicle Mileage
1. 1,200 Miles (Owner)
2. 7,500 miles (Owner)
3. 15,000 miles (Dealer)
4. 22,500 miles (Owner)
5. 30,000 miles (Dealer)
Kyngofpop676.00
      07-20-2010, 10:36 PM   #2
Jason
Administrator
Jason's Avatar
40828
Drives: F80 M3
Our first DIY! And a great one at that. Thank you for sharing.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      07-20-2010, 11:20 PM   #3
LACSTER
759
Drives: Hybrid
Awesome write up but all i'm capable of doing is drinking the beers at the end
      07-21-2010, 03:03 PM   #4
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
What's 'Heineken'?
      07-22-2010, 11:52 AM   #5
ogrady
ogrady's Avatar
88
Drives: AW 09 335
Does BMW recommend a post-break-in oil change or you did the 1100 mile oil change just to be safe?
      07-22-2010, 12:02 PM   #6
gatoman39
gatoman39's Avatar
116
From Mike Miller:
Old School BMW Maintenance Schedule:
Break-in Service for New Cars
Traditionally, BMW performed a break-in service at 1,200 miles on new cars, which included changing the engine oil and filter, manual gearbox oil or automatic transmission fluid, and differential oil. With the advent of Free Scheduled Maintenance, BMW stopped performing break-in services except on M cars.
I have seen that the engine and driveline oils in new modern BMWs are literally full of metal at 1,200 miles – as has always been the case with any new car. For this reason, I recommend a 1,200-mile break-in service.
      07-22-2010, 01:58 PM   #7
BimmerMat135
699
Drives: E82M/S213 E450 A/T
Originally Posted by gatoman39 View Post
From Mike Miller:
On all M cars they will perform an oil change at 1200miles part of the free scheduled maintenance?
      07-22-2010, 02:04 PM   #8
kinan_sleiman2006
kinan_sleiman2006's Avatar
Syria
84
Drives: BMW X3
i preffer to do this in an offical bmw service workshop
      07-22-2010, 02:14 PM   #9
danniexi
danniexi's Avatar
No_Country
3068
Drives: 2022 F97 X3M Comp LCI
Originally Posted by Robin Hood View Post
What's 'Heineken'?
fuel additive manufactured from the netherlands. add it to the fuel tank after every oil change. it'll clean the injectors and the entire fuel system. adds an extra 15+ whp. use heineken lite if you're not tuned.
btw, great diy. car looks great!
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE
BMW MY08 E92 335XI - GONE
BMW MY06 E46 325XI - GONE
      07-22-2010, 02:35 PM   #10
gatoman39
gatoman39's Avatar
116
I honestly don't know, according to Mike Miller's article they did, or do. Can any recent M owners confirm or deny free 1200 mile oil change?
      07-22-2010, 02:47 PM   #11
bavarian19
General
bavarian19's Avatar
517
Drives: Car
      07-22-2010, 02:47 PM   #12
Reznick
Reznick's Avatar
24
Drives: 08 M3 ,01 330,M240?
A $65,000.00 car and a $35 jack. I see you've been shopping at Harbor Freight again............ I'm just bustin ya. Obviously I've been grabbin stuff from there too, or I won't know that "U.S. General" means Made in China. Good write up. Nice to know there are other BMW drivers out there that will get their hands dirty
      07-22-2010, 03:07 PM   #13
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
What's 'Heineken'?
no way...
Op, well done and nice and clear diy.
F30.F11.E86.E90.E90.E36
      07-22-2010, 03:10 PM   #14
mtechnik3
mtechnik3's Avatar
415
Drives: 2020 M2C
Great write-up, thanks for sharing! I've follow Mike Miller's guide for my E90 as well.
The last step is the best.
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i
      07-22-2010, 03:12 PM   #15
eurotechnik
M POWER
eurotechnik's Avatar
Drives: BMW
Yes! All M's and Alpina vehicles come with a 1200 mile break in oil change. Which includes a transmission (only on manual vehicles) and diff oil change.
      07-22-2010, 03:18 PM   #16
gatoman39
gatoman39's Avatar
116
On a car I bot last year, what I concluded from Used Oil Analysis (and others like it) is that the early oil changes should not be extended due to the engine needing to break in. BTW, this car also uses the 6 speed ZF found in the E60 and cartridge oil filter housing made by Mahle.
Dumped factory fill at 1200 miles
Mobil 1 5W-30
10 months and 5600 miles later...
      07-22-2010, 03:22 PM   #17
SCPACKAGING
Drives: 2011 BMW 535
Yes, prior to taking delivery of my '11 535 I had a 2008 M5 on a two year lease and as part of the maintenence program they did the break in service at 1200 miles.
      07-22-2010, 03:48 PM   #18
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
Thanks for the write-up.
I appreciate those engineers that design small simplistic items such as the trap door on the shield; Rather than taking the whole shield out to gain access to the Oil pan nut.
      07-22-2010, 04:36 PM   #19
joberon
Drives: E92
From Mike Miller:
Just curious: when you performed this oil change, did you actually see any metal or other foreign objects? From the pics it looks pretty clean...
Driving: 11 F10 528i
Memorium:07 E92 328i, 04 E46 325ci, 87 E30 325e, 76 E6 2002ti
      07-22-2010, 04:45 PM   #20
gatoman39
gatoman39's Avatar
116
No, I surely did not see any metal, not that I was looking. I believe the metal and basic elements may be suspended in the oil, or in a form that is not clear to the naked eye. As you can see from the Used Oil Analysis, there are a lot of individual metals and elements they can test for. From what I could tell the oil looked clean and thin, not that you can tell much by simply looking at it.
      07-22-2010, 06:49 PM   #21
Oulixes
Oulixes's Avatar
22
Drives: 330xi, 335i
Good report. The N55 uses the same filter and oil as N52 and N54.
      07-22-2010, 09:42 PM   #22
BMWPower06
A^M=G is nothing w/o the Power of ///M
BMWPower06's Avatar
171
Drives: ///M5 & ///M3
Great write up!
Indianapolis Red BMW ///M5
5post
