335i lurches, anyone else?
12-27-2006, 01:07 AM | #1 |
50
Rep 1,600
Drives: e90 335i
So I got my 335i back from ED about a week ago (e90 335i) and it was delayed for almost 3 weeks from the ship arriving to me getting it from the dealer because they were holding it at the VPC to do the software update Cold start and maybe a couple of other things). i am loving having my car back but I noticed it does something that it didnt do at all in Europe. When I take off from a stop, say at a light, when i press on the gas even in non-sport mode the car hesitates for a second then takes off so that it is hard to get a smooth takeoff at times. Otherwise it drives awesome and I cant say I notice any appreciable change in power but this jumpy start is definitely new and I have to assume it is related to the software update. Anyone else getting this?
Thanks, Kevin |
12-27-2006, 01:39 AM | #2 |
98
Rep 3,618
I find this is just a characteristic of drive-by-wire throttle systems in general, Mercedes gas pedal feel is even worse from a complete stop. But for a 335 in particular, combine that with the low rpm's it needs to produce torque and it just elevates the "problem". You'll get used to it, give it some time and your foot will figure out how to make a smooth take off
Edit: What were you driving inbetween while waiting to have the car back after doing ED? Probably quite a contrast too I'm betting.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
12-27-2006, 01:50 AM | #3 | |
50
Rep 1,600
Drives: e90 335i
Thanks for the replies. Yeah I guess I'll get have to get used to it. I'm wondering if it will seem better or worse if I get the Xede. I have been driving a 2002 ML320 (my wifes old car) so yeah there is a big difference in low end torque to say the least . Thanks for the replies, Kevin |
12-27-2006, 07:19 AM | #6 | |
Car Junkie
21
Rep 1,279
Drives: 335is / R8
+1 Had this with my cls500 & a6 also |
12-27-2006, 09:20 AM | #7 | |
Shadow Warrior
139
Rep 2,095
Took me awhile to get used to as well. You'll just have to learn how much gas to give it till you can pull off a smooth start. I was trying to give it the same amount of gas I'd give my mom's '95 Honda Accord, and yea umm that doesn't work the same way Try depressing the pedal slightly and keeping it there till it launches... resist the urge of pressing it further... vary the amount of depression till you find the spot that gives you a non-lurching start. BTW I had the same prob when test driving the 330i too, wasn't totally used to it. The 335i seems a bit more pronounced though.
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods: PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar Installing soon: Rear Power Outlets (Happy Robot mod!) |
12-27-2006, 09:52 AM | #8 |
21
Rep 257
i have a TSX as well that has drive by throttle and it doesnt do this at all, i have noticed this with my 335 but it seems worse when the engine is colder, i am wondering if i have that hesitation problem others have been reporting.
2010 335i xDrive Sedan
Saphire Black Metallic | Saddle Brown Leather | M Sport Package | 2008 X5 4.8i M Sport Edition Ruby Black - Individual | Saddle Brown leather | Bamboo Trim | M Sport Package | |
12-27-2006, 10:24 AM | #9 | |
50
Rep 1,600
Drives: e90 335i
12-27-2006, 11:53 AM | #10 |
Expert Road Racer
59
Rep 1,329
DS mode for me helps, and learning to drive around the lurchy conditions also helps. Coasting to a stop, not stopping completely, getting on gas hard = lurch. Cold start = lurch if aggressive with throttle. I attribute the lurch to not knowing whether to be in 1st or 2nd gear along with the quick lockup converter.
Manual mode gets rid of it completely! |
12-27-2006, 12:09 PM | #11 | |
56
Rep 1,047
Based on that I think I am going to order them as well. |
12-27-2006, 01:17 PM | #12 |
Rep 161
I wonder if the following has something to do with it. I found it in the Sedan brochure, not the coupe, but I assume the technology is the same. The brochure says the following: "3. Start-Off Assistant: DSC helps prevent your vehicle from rolling backwards or forwards when you're stopped on a hill. It even holds your car momentarily when you release the brake to start moving again".
Now, I wonder if it kicks in even in a slight incline -- I'm speculating of course.
ED Jan 29 2007, redelivery apr 14 2007 - 328xi coupe monaco blue/saddle brown sport premium cold nav step comfort access
http://www.e90post.com/forums/showthread.php?t=45881 http://www.bimmerfest.com/forums/sho...d.php?t=187322 |
12-27-2006, 04:02 PM | #13 | ||
98
Rep 3,618
12-27-2006, 04:44 PM | #15 |
Razor sharp handling
23
Rep 619
Yep, mine lurches a bit. It's nothing compared to the wild lurching and bucking of my other turbo car, but it's enough to notice. This happens for me only under mid-throttle. If I give it very little gas or a lot it does not lurch at all.
1997 E36 328is Arctic Silver: 1997-2003 100k Mi. SOLD
2000 Audi TT Quattro Coupe Lake Silver: 2003-present 35k Mi. SOLD 2006 Lotus Elise Polar Blue/Red 2007 E92 335i Spacegrau/Coral/Al | ZSP/ZPP/ZCW/CA/PDC/NAV Broken in |
12-27-2006, 05:06 PM | #16 | |
16
Rep 217
Hmmm...isn't that feature only on manual tranny cars? I have it on my six speed and I believe it's primarily for the hill starts to prevent roll when releasing the brakes. It's an awesome feature but as soon as you even tap the accel pedal, the hill assist releases the brakes and does not interfere any further. I don't believe that this system has anything to do with the lurch on auto trannies. I could be wrong though.... |
12-28-2006, 10:13 AM | #18 |
40
Rep 361
Drives: E70 X5 35d
I think that this must depend on driving style as I just don't seem to experience what you guys are talking about. I also don't feel like I'm fighting with the hill braking (or whatever it's called) that some have complained of. The only thing that I have to adjust to when I get into the 335i after another car is the touchiness of the brakes, which feel a bit overboosted to me.
12-28-2006, 10:40 AM | #19 | |
262
Rep 1,389
Drives: 2012 E92 M3
I would not just deal with it! I had this same problem with my X5 and my E46 330ci. They were both manual but the problem is caused by the drive-by-wire and not the transmission or the CDV. Some cars have it and some don’t. It’s has nothing to do with driving style. If you mash the gas pedal, the car should take off not sit and think about it for half a second and then get up and go. Lucky for me my E90 does not have this problem but why the FUCK hasn’t BMW fixed this problem yet??????:mad: :mad: :mad: :mad: :mad: :mad:
12 M3 Interlagos Blue/Black
18 Jeep Grand Cherokee (Yeah, it's got a HEMI) 21 X3 Silver/Black(Wife's) 06 330i Monaco Blue/Black (retired) 02 X5 3.0 Topaz Blue/Black (retired) |
