WTS: SSTT +40 hp
07-19-2010, 11:30 AM | #1 |
lurker
24
Rep 130
WTS: SSTT +40 hp
Had this on my 135i for about 5000 miles and took it off (scared of dealer codes). Now the lease is due, and it wont work on my new N55 model. $125 shipped seems like the going rate. Let me know if you want it! --MW __________________________________________ The Turbo Tuner is a plug-and-play solution that significantly enhances performance on the BMW 335i. Typical gains are 40 horsepower and 50 ft-lbs of torque. It is designed to be an easy-to-use solution that end users can install themselves. The Turbo Tuner can be installed or uninstalled in seconds. It does not cause any trouble codes and its operation does not leave any trace that it was ever there. The Turbo Tuner is not an ECU re-flash solution. It is an embedded control solution that works seamlessly with the stock ECU. The turbo tuner provides real performance gains while it preserves the smooth and refined character of the car. A version of the Turbo Tuner is also available for the Porsche 996 and 997 Turbos. http://eurobahnmotorsport.com/split_.../i-151856.aspx |
08-16-2010, 03:28 PM | #14 |
lurker
24
Rep 130
ok! I pm'd you with my phone and paypal info. If you send the $$ tonight, I'll ship it tomorrow first thing. If it makes you feel better to chat first give me a call. Thanks! --MW
