Illegal headlights and foglights?
12-26-2006, 03:48 AM | #1 |
304
Rep 1,928
Drives: had e90, 330i mystic blue
so today one of my friends point out that my car does not turn off the foglights went I turn on my highbeams and that's illegal in some if not all states. I'm happy that my car does not turn them off but what if I get a ticket? is BMW fault!!!
another thing that I find out is why does the headlamp lens cleaning sys is not standard in all BMW with HID :mad:there is a ECE regulation that required all car that have HID to have them, why BMW charge extra for it ( cold PK)
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML |
12-26-2006, 07:21 AM | #4 |
Rep 22
How about the machine gun button on my shifter? Is that ok for a US delivered car? Remember that I live in Los Angeles so maybe that's why it was automatically optioned.
12-26-2006, 08:08 AM | #5 | |
Rep 84
My Fogs stay on when high beams on as well.
J Quote:
2011 335i Cabrio, MSport, PP, NAV
12-26-2006, 08:12 AM | #6 | |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
12-26-2006, 08:12 AM | #7 | |
26
Rep 521
12-26-2006, 08:20 AM | #8 | |
Rep 84
12-26-2006, 08:24 AM | #9 | |
156
Rep 10,411
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
12-26-2006, 09:50 AM | #10 |
274
Rep 6,510
why would it be law? you only use your high beams when no one is around anyway...
I always thought that it was because of current draw of the lighting... the electrical system couldnt handle it... but now with the adaptive xenons, its not more bulbs that turn on for the high beams, its just the lens shutter moving up... no additional power draw. Thats my theory.... |
12-26-2006, 10:08 AM | #11 |
Razor sharp handling
23
Rep 619
Fog lights can't be on without parking lights
Fog lights can't be on with high beams Fog lights can be on with low beams Fog lights can be on with parking lights Fog lights should only be used in fog Fog lights are positioned low to allow you to see the road in heavy fog or snow without causing haze and reflection in front of the car. In the heaviest snow and fog, it is easiest to drive with just foglights and parking lights on, and headlights off. You'll know what I mean when you try it, although I believe this may be illegal. From the NY DMV website: http://www.nydmv.state.ny.us/dmanual...r10-manual.htm DRIVING IN RAIN, FOG, OR SNOW ... Rain, fog, or snow makes it harder to see out through your vehicle's windshield, and difficult for other drivers to see you. New York State law requires you to turn on your vehicle's headlights whenever the weather conditions would ordinarily require the use of windshield wipers to clear rain, snow, sleet, and other precipitation. "Daytime running lights" do not qualify as headlights. If your windshield wipers cause streaks or smears, the blades must be replaced. High headlight beams reflect off rain, fog and falling snow. This makes it even harder for you to see where you are going. For better visibility during these weather conditions, keep your vehicle's headlights on low beam. Reduce your speed. Signal your turns further ahead of time than usual to give other drivers and roadway users increased warning. Brake early when slowing behind another vehicle or coming to an intersection stop. Some vehicles have front fog lights, or front and rear fog lights, for use when heavy fog or similar hazardous weather conditions seriously restrict the driver's visibility. In New York State, all fog lights must be properly installed and of a type approved by the Commissioner of DMV. Front fog lights may be amber or white in color. Rear fog lights must be red and may be larger than the vehicle's regular taillights - they are intended to give advanced warning of your vehicle's presence to the drivers behind you. When visibility improves, you should switch off your vehicle's rear fog lights to reduce the glare that might affect other drivers.
1997 E36 328is Arctic Silver: 1997-2003 100k Mi. SOLD
2000 Audi TT Quattro Coupe Lake Silver: 2003-present 35k Mi. SOLD 2006 Lotus Elise Polar Blue/Red 2007 E92 335i Spacegrau/Coral/Al | ZSP/ZPP/ZCW/CA/PDC/NAV Broken in |
12-26-2006, 10:54 AM | #12 |
173
Rep 3,415
The reason some cars have fog lights on with high beams and some that don't is because of the type of headlight the car has. HID cars keep the fogs on with the highbeams and halogen equipped cars headlights don't. The reason is a federal law (U.S. vehicle code) only allows that two (2) lamps (bulbs) per side can be lit at one time. All four-lamp Halogen BMWs have two bulbs lit per side (four total) in high beam. The HID cars can have the fog lights on in highbeam because HID headlights use the same bulb for both low and highbeam. There is a shutter in the HID lamp that refocuses the bulb for highbeam, so legally, an HID car only has two bulbs lit per side when the fog lights are on and it is in high beam mode.
12-26-2006, 11:03 AM | #13 |
576
Rep 6,750
What "authorities" will actually notice your high beams and fog lights together? We usually dim them with oncoming traffic or upon closely approaching traffic in the same direction. Don't worry. I'd be happy!
12-26-2006, 11:14 AM | #14 |
40
Rep 361
Drives: E70 X5 35d
(Where's the soapbox smiley on this site, or is it just assumed to be the norm?)
I'm in the group of folks who do not like it when others use their fog lights all the time. These lights aren't designed for use in normal conditions, and they're not providing anything more than a misguided sense of security because the driver thinks that they can see more of the road. What is it about the things on the side of the road, and that which is about to go under the car, that is so interesting? Unless you're going 5 MPH and hunting for something you've lost on the ground, keep your eyes up and pay attention to what is ahead and behind you. At highway speeds you're not going to be able to react to the things that you can see "better" because of the foglights, and they're likely to serve as a distraction. Besides being inconsiderate (and making you look like an ass), using fog lights in unwarranted conditions is illegal in many states. Check your DMV and you may find that you must dim fog lights just as you must dim high beams. For example, the law in Colorado is as follows: "If you are driving with your high beam lights on or your low beam lights with fog lights on, you must dim them before coming within 500 feet of any oncoming vehicle so the oncoming driver is not blinded by the glare." "When following another vehicle, you must use your low beam lights, with your fog lights off, if you are within 200 feet of the vehicle ahead of you." If you can't see well enough without the fog lights, you should a) have your headlights checked for proper adjustment b) have your eyesight checked c) learn to keep your eyes up and pay attention to what's important Flame on if you feel the need, but if you insist on using your fog lights all the time then you're probably breaking the law. At least try to be considerate and dim them when you're within 500 feet from their front and 200 feet from their rear. |
12-26-2006, 11:22 AM | #15 |
Moderator
618
Rep 10,855
I always drive with fogs on in addition to headlights, and am pleased that they stay on with xenon brights (whereas they turned off in my E46 w/halogens -- as per DOT regs). The reason is that they help illuminate animals like deer that are off the side of the road. The spread is low and spread out wide for coverage beyond standard low beams.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
12-26-2006, 12:11 PM | #16 |
Rep 84
Every post someone needs to preech about what not to do. Don't tell me not to use my fogs. I use them when I choose to. I don't use them most of the time but when I decide to turn them on I will turn them on.
J
12-26-2006, 12:23 PM | #17 | |
21
Rep 297
12-26-2006, 12:56 PM | #18 | |
4972
Rep 10,200
12-26-2006, 02:49 PM | #19 |
4972
Rep 10,200
Oops--what I said was right above my post--I always thought it was yards, not feet, but now that I think about it, feet makes more sense.
12-26-2006, 05:02 PM | #20 |
335
Rep 2,385
I am rarely blinded or annoyed by anyones fog lights being on in the wrong conditions. Although occasionally by some stupid over sized wannabe hillbillies F-250 or equivilant. The more annoying of the fog light dilema is someone who runs around with their rear fogs on. I agree that is stupid. But the whining about front fogs is not needed, unless you have xenon fogs and they are aimed upwards. You then would deserve a swift kick to the right testicle(or ovary lol).
retired 06 E90 325i New: 09 VW Platinum Grey Jetta Sportwagen 2.0T SEL w/DSG, panoramic sunroof and Ipod adapter |
12-26-2006, 05:25 PM | #21 | |
21
Rep 297
12-26-2006, 06:35 PM | #22 | |
335
Rep 2,385
There ya go.
