How much should I pay for wheel installation
07-16-2010, 02:13 AM | #1 |
Rep 56
About to get the 19" 313's for my 09 328 coupe... Should I install at BMW so I can make sure that the tire pressure monitor will work or do you guys see no issue with taking it to any wheel / tire shop?
How much would BMW charge? How much should I pay? Thanks |
07-16-2010, 02:15 AM | #2 |
109
Rep 1,830
Well, if nothing needs to be coded and does not involve engine/tranny work, it's best to just take it to a reputable specialty shop. Go to Discount Tires or something. They call them Stealerships for a reason.
07-16-2010, 02:51 AM | #5 |
Where'd my VTEC go?
481
Rep 6,067
Make sure its a good shop that has done expensive wheels before and not just some random tire shop down the street that works on 14" steel Corolla wheels all day. Last thing you want is for the shop to scratch up your shiny new wheels when mounting tires.
07-16-2010, 05:47 AM | #7 | |
103
Rep 2,783
07-16-2010, 06:57 AM | #8 |
41
Rep 220
07-16-2010, 07:10 AM | #9 | |
922
Rep 5,538
Indy shop here charges $20 per wheel just to balance on roadforce. Ps. I had bad experience with roadforce/indy shop, and therefore don't use it anymore Went to balance my wheels on m3 2 times on roadforce without luck, then went to dealer and told them that there must be some problem with the car, they asked me where balanced and laughted at me..... Since manager was my friend they rebalanced for free and everything was fine Last edited by Kolyan2k; 07-16-2010 at 07:18 AM.. |
07-16-2010, 07:39 AM | #10 | |
41
Rep 220
Matter of fact the local BMW/Mercedes dealer has a roadforce machine as well, but like everything else in the world it only works as well as the people are trained |
07-16-2010, 07:55 AM | #11 |
865
Rep 5,450
Dealer here charges $50 a wheel, almost no one else will touch the runflats around my area, without the proper tire machine for run flats, they will most likely damage the rim!
First place I tried was the place that actually repairs all BMW dealers damaged wheels, even they where afraid to try doing the tires as they did not have the right machine (but had ordered one!). A good indy shop should have the right machine as they should be used to doing runflats, but I would stay away from the chain tire shops as some kid will destroy your wheel learning about runflats the hard way!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-16-2010, 08:36 AM | #12 |
14
Rep 434
I've done this at my dealer for $30/wheel with balancing. I was quoted the same at an indy shop so I just decided if any issues arose the dealer would be more professional since I know them better.
I would recommend asking around for a good shop and then make your choice, any of them is fine. |
07-16-2010, 09:12 AM | #13 |
5330
Rep 1,912
As others have stated $20/corner is about the average price. However make sure the place has the proper equipment. Many Tire Kingdoms and the like are not setup to handle 19" runflats and they will mess up your wheels (top of the line machines can cost $20k and they don't see enough 19" wheels to make it worthwhile). I would just ask the shop before hand if they can handle the tires. Other than that any decent shop will do you don't have to go to the dealer.
09-24-2010, 02:55 PM | #15 |
BimmerPost Supporting Vendor
2040
Rep 25,989
Mounting of wheel/tires should not cost an arm and a leg. Iv seen most shops charge about $80-120 to mount and balance 18-19" wheels + another $30-40 to physically mount it onto the car.
I would recommend checking Tirerack.com's authorized shops for your wheel/tire work. http://www.tirerack.com/installer/index.jsp -Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
09-24-2010, 03:10 PM | #16 | |
Happy Camper
613
Rep 7,869
Drives: C63 AMG & 280 SL on Weekends :
Garage List 1969 Restored Merce ... [7.50]
2011 M3 Coupe TRADED [7.34] 1987 BMW 535is [1.00] Cars from the Past [6.50] The ///M3 Engine S65 [9.59] |
Photo 3 and 4 show what inexperienced tire shop people do to your wheel and believe it or not this tire shop is being used by a BMW dealership in a small Idaho town, since the BMW dealership only is capable of checking your air pressure and cannot change your tire to a new wheel they ordered for me since they don't have the manpower or the equipment to do so, go figure.
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too ---> Click here for some good stuff I found |
09-24-2010, 03:44 PM | #17 |
20
Rep 339
Good call on going with TPMS from the start - I cheaped out and went with tires/wheels only and now I'm going to have to pay dismount/mount for a second time to get the TPMS in.. the dash light is annoying
2007 328i coupe - Sport, Premium
2010 Ducati Monster 696 |
