Oil question...
07-10-2010, 12:49 PM | #1 |
97
Rep 2,834
Oil question...
Hello peeps,
Quick question, my 335d has Castrol Edge TD 0W-30 in it already but it needs a top up, I believe the 0W-30 has been discontinued, is it ok to now just top it up with 5W-40? Or do I need to do a complete change to prevent mixing of grades? |
07-10-2010, 12:51 PM | #2 |
Moderator
324
Rep 5,493
You can top up with 5w-40
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
07-10-2010, 05:47 PM | #3 |
97
Rep 2,834
Cheers fella. As luck would have it I found a litre bottle of 0W-30 and banged that in. Weirdly though, adding a litre only brought the level up to halfway between the min-max marks on the dipstick. According to the handbook the difference between min/max is supposed to be spot on 1 litre. WTF is going on there?? I will grab some more 0W-30 if I can failing that, Halfrauds have a special on where if you buy 4L you get a 1L free so will just grab some 5W-30 on that offer and keep the 4L for when it's service time (which will be later this year). Thanks again Tony. |
07-10-2010, 06:10 PM | #4 |
LSD - No, you're not seeing things
72
Rep 3,302
I believe Castrol are rebranding the Edge range soon, to do away with 'Diesel' and 'Petrol' oils, combining them into one product.
I have used the Diesel Edge in my petrol performance cars for years. It carries the VW 505.1 which according to those in the industry, is quite a difficult approval to achieve. |
07-11-2010, 10:49 AM | #6 |
Moderator
324
Rep 5,493
Perfectly fine to use
07-11-2010, 11:12 AM | #7 |
97
Rep 2,834
Thanks mate.
The Halfraudsters had the Castrol EDGE Turbo Diesel 5W-40 on offer, got 2x 4L and 2x 1L for £80. Means I have two 1L bottles for top-ups and enough for a service later in the year Just a general question, I've been reading up on oil grades. Would I be correct in saying the following: When at operating temperature, the 5W-40 will be more viscous than the 0W-30. Therefore 5W-40 will therefore be offering more protection when the engine is up to temp. Also, the 5W-40 will be slightly more viscous when cold, does this mean slightly less protection is on offer when the engine is cold as it will take a bit longer to get moved around and properly covering the various components? Just trying to understand and learn a bit more. |
07-11-2010, 08:14 PM | #9 |
Weekend Rockstar
39
Rep 728
why not check out the other thread and get an oil change - all done and dusted at NATIONAL for £32 - all in?????
not worth fckin about yourself for that
E92 M3 - Interlagos Blue and Black everything else!!!
