E90 Lci Help!
06-30-2010, 04:39 PM | #1 |
Rep 382
E90 Lci Help!
Hey guys hopefully you guys can help. I'm looking to buy a set of wheels.these to be exact (http://www.e90post.com/forums/showthread.php?t=385831). and wondering if they fit on my LCI 328 2009. And what tire sizes should i get.
06-30-2010, 04:46 PM | #2 |
Wang D.D.S.
185
Rep 7,057
Those offsets are pretty aggressive, but I don't think it's impossible to fit on an LCI. Keep in mind that LCI has a higher offsets comparing to pre-LCI by about 3-4mm (I could be wrong).
I would say if you are not planning to lower your car, 235/265 tires are gonna be just fine. If you are lowering, fender roll all 4 corners and go with something like 225(235)/255 combo.
06-30-2010, 05:00 PM | #3 | |
Rep 382
06-30-2010, 05:15 PM | #4 |
475
Rep 13,583
Drives: JB E92 335i
The setup is far too aggressive and will not work properly on your vehicle. You might be able to get it to work if you roll your rear fenders and run a stretched tire in the back. The ideal setup for your E90 LCI is going to the 19x8.5 ET35 in the front and 19x9.5 ET40-43 in the rear. I'll shoot you over a PM with more details
- Alan |
06-30-2010, 05:23 PM | #5 | |
Wang D.D.S.
185
Rep 7,057
I do still think the wheels will work, it's just an aggressive setup. If you want the true flush, go for it.
06-30-2010, 11:59 PM | #7 | |
Wang D.D.S.
185
Rep 7,057
So what if you have 11" et20 on your LCI...!?!?
07-01-2010, 12:15 PM | #9 |
General
1569
Rep 29,202
Not exactly a new member, just new name.
07-01-2010, 01:26 PM | #10 |
Wang D.D.S.
185
Rep 7,057
Oh wait....... is this.... that dude who got banned for bragging how good he/she is at the hella-flush look??? If so, then I will leave it along.
07-19-2010, 08:50 PM | #11 | |
Ex-Diesel Driver
63
Rep 2,000
FS: HRE Center Caps http://www.e90post.com/forums/showth...post13972317l] |
07-20-2010, 11:29 AM | #12 |
BimmerPost Supporting Vendor
2042
Rep 25,989
Front and rear fitment is extremely aggressive for a Non-M. Fronts will require some slight camber while the rear will require fender rolling with some slight pulling if you plan on using anything wider then a 255.
This setup can work, depending on how much elbow grease you are willing to put into it like MassBimmer had mentioned. I generally recommend a 8.5 +35 front with a 235 tire and a 9.5 +45 rear with a 275 tire. This is flush on all 4 corners without the need of any kind of fender work at stock/sport height. -Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
07-20-2010, 07:09 PM | #13 |
General
1569
Rep 29,202
Sounds good.
07-21-2010, 04:47 PM | #14 |
114
Rep 1,323
As said above, those sizes are aggressive but could work with some fender rolling and careful selection of tires. I would chose a 225/255 setup on a Toyo T1R or Nitto Invo. Rolling and some extra camber will most likely be necessary
