06 325i overheating
06-20-2010, 10:55 PM | #1 |
16
Rep 178
06 325i overheating
It was very hot in Houston today! I was driving to my Mom and Dad's house for Father's Day this morning, about 40 miles away. I was just a couple of miles from their house when bam! yellow temp warning, then two seconds later bam! red temp warning and the car goes into limp mode. Luckily, I'm right at the freeway exit, so I turn off the AC and turn the heater up to max and creep the last two miles to their house. When I get there, I pop the hood and the fan is still running full blast. I see a bunch of coolant has leaked out from under the pressure cap, with coolant all over the wheel well. I let it cool down for an hour or two then open the pressure cap. I put about half a gallon of 50/50 coolant/ water mix into the overflow reservoir. We decide to press our luck and head back home. On the way home, same thing- after driving at 75-80 MPH for 30-35 minutes, bam! yellow bam! red. Limp home once again, pop hood, lots of coolant leaked out from under the cap.
My question is: is this just a simple matter of a failed pressure cap? I sure hope so! What else could cause the coolant to blow out from under the cap like that? I figure a stuck thermostat or blown water pump would cause overheating much faster than 35 minutes in 100 degree weather. I don't see any coolant leaking under the car when parked. |
06-20-2010, 11:42 PM | #2 |
103
Rep 2,783
It is either the water pump or thermostat. See my sig, it should be throwing a code.
10-11-2010, 03:19 PM | #5 |
103
Rep 2,783
^ I thought you were encountering a coolant fan issue? Now it's your water pump and thermostat?! That sux.
