Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Run-Flats = Twitchy at high speed?
      12-16-2006, 01:43 AM   #1
850CSi
16 years and counting...
850CSi's Avatar
101
Drives: '06 325i 6MT
My 325i is equipped with the standard run-flats (16").
I've noticed that once you get above around 95 MPH, the steering starts becoming a little twitchy. Anyone else having the same issue?
I've heard a lot about run-flat tires in general being subpar at high speed.
Another thing... As I'm driving along, I often hear this whirring noise coming from what seems to be the wheel wells. I used to think it was just the engine and my ears playing tricks, but today I was revving the engine as I was moving along, and the noise is constant - not from the engine.
I remember having a similar problem before in my A4, turned out to be bad bearings. The Bimmer's only at 15K miles, could it be a similar issue?
E90 325i 6MT + E61 530xiT 6AT = N52B30*2
      12-16-2006, 06:08 AM   #2
bmwexecutive
bmwexecutive's Avatar
241
Drives: 2006 330i
At 15,000 miles you better check your tires because the RFTs aren't rated for much anything more than 15,000 miles. Check to see if wear bars are showing. I recommend you pick up a set of Michelin Pilot Sport PS2's. At 130MPH they are about as stable as it's going to get, plus very little tire noise and they are extremely comfortable in ride compared to the RFTs.
      12-16-2006, 01:33 PM   #3
Utekai
Drives: 335i
[QUOTE=850CSi]My 325i is equipped with the standard run-flats (16").
QUOTE]
I spent quite some time on run flats in speeds in excess of 120mph, right to 155mph and the tires felt great, no different. Maybe you've got a balancing or alignment issue?
