► Check Engine: Thermostat @ 30k miles
06-16-2010, 09:53 PM | #1 |
Montreal R-Spec
17
Rep 180
I just had my thermostat replaced this morning @ BMW Park Avenue Brossard. The Tech told me that the thermostat was left OPEN. My car only has 30k miles. Obviously its not normal.
What could cause this to happen at an early stage? I don't drive hard. TRUST ME! (stored in winter also!) If I look on the bright side, I have a brand spanking new thermostat + coolant for free thanks to CPO warranty... But still... Anyone else on the forum change their thermostat early? .
MARK ALEXANDER
▀▄ 'O6 330i | 6MT | Sport Package | Black Sapphire Metallic | Aluminum Trim | Black Dakota Leather | H&R Sport Cupkit | AFE Intake | Matte Black (Dipped)162's - BFGoodrich g-Force T/A KDW | 18mm Rear Spacers | ECS CF/Aluminum Strut Bar | M3 Sways | Depo Blacklines | |
06-17-2010, 06:50 AM | #2 |
103
Rep 2,783
1) Your car is an 06 so age is the factor. Some people think (not talking about you) that if they bubble wrap their car and open it in 10 years it is still new. Just not true.
2) Consider yourself lucky, the thermostat and coolant are not covered here in the US. 3) Your thermostat failed because the coolant was old and "lifetime" therefore it was not getting proper lubrication (coolant not only "cools" but lubricates). Over time it loses its lubrication properties. At least they changed the coolant and your water pump will probably last longer.
06-17-2010, 09:56 AM | #4 | |
814
Rep 3,953
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
06-17-2010, 10:00 AM | #5 |
124
Rep 5,627
Thermostat on my E46 was replaced under a recall at 32k and the replacement went south 50,000 miles later. At least they all seem to fail in the open position.
Tom |
06-17-2010, 10:09 AM | #6 |
Powered By 36DD
337
Rep 7,369
got my water pump and thermostat replaced..........a few months back
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
06-17-2010, 11:32 AM | #7 | |
103
Rep 2,783
06-17-2010, 11:44 AM | #8 |
103
Rep 2,783
Your lucky, the two I replaced on my e46 both failed in the closed position (car overheated). Note: I only replaced the thermostat 2x in 184,000 miles (not bad).
06-17-2010, 12:59 PM | #9 | |
814
Rep 3,953
06-17-2010, 02:13 PM | #10 | |
103
Rep 2,783
06-17-2010, 03:24 PM | #11 | |
814
Rep 3,953
http://auto.howstuffworks.com/cooling-system8.htm
06-17-2010, 08:18 PM | #12 |
103
Rep 2,783
^ Good to know. I was always under the impression that antifreeze lubricates the water pump AND T-stat. It looks like it just lubricates the water pump.
06-18-2010, 08:24 AM | #13 |
814
Rep 3,953
One day, cars may not even need a stat with active aerodynamics that open and close vent doors in front of the radiator.
