I don't think I'm pre-wired for Sat?
06-16-2010, 03:59 PM | #1 |
Rep 13
Drives: Tundra Crew - 89 RX7 Racecar
My Fiance really wants sirius in our 07 335i sedan sport/manual car. I looked under the mat in the trunk this morning, there is only one module under there with COntinental stickers on it, so I assume we are not pre-wired for satellite? This means I have to go with an aftermarket system correct?
Thanks, Carl |
06-16-2010, 09:18 PM | #2 | |
Rep 72
If you want to install the BMW system then check out this DIY thread. http://www.e90post.com/forums/showthread.php?t=10536
2007 328i Coupe Auto | Monaco Blue | Cream Dakota | Premium | Sports | CIC retrofit | 6FL Retrofit | Logic 7 Retrofit
06-16-2010, 11:48 PM | #3 |
289
Rep 3,201
Pre-wired doesn't mean you have a module... the big question is CAN spec. US spec 2007 would have prewire. CAN, I'm not certain, but your test method isn't what I would use.
06-17-2010, 04:24 AM | #4 | |
620
Rep 2,013
06-17-2010, 06:55 AM | #5 |
34
Rep 221
The only way to know is to look at the options your car came with. You can either get it from BMW (go see your SA) or contact a vendor (like Patrys, who volunteered), who can then look up the options list for your VIN. If the options list says SA 693 SAT PREP then you have it, if not, then you need to go the direction @lesliew pointed you in.
