hit a retread on the road and dented from grrrr
06-16-2010, 09:31 AM | #1 |
Rep 27
was behind a pt cruiser and he nailed the tire and then it flew into me
i had no time to swerve so now i don't know what to do should i just push it back out and put an aftermarket oem lip on it? |
06-16-2010, 09:40 AM | #5 |
Jerry's Fault...
175
Rep 9,258
Should be able to, if when you pull your OEM back out, the lines aren't messed up and creased in any way that would cause the aero lip to not sit flush. I'm pretty sure the shop can make minor adjustments to make it fit afterwards anyway but yea u should be able to
06-16-2010, 11:03 AM | #7 |
103
Rep 2,783
At first glance I thought you wrote "hit a retard on the road". I was thinking WTF?!
06-16-2010, 11:41 AM | #13 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
I ran over some jackasses bungie cord with the S hook on both ends, and so far I cant see anything but havent looked real hard yet as I heard a thuddish kind of sound. So a metal S hook had to hit somewhere I just hope it wasnt anything noticible or mechanical.
PS Sorry for your Bad Luck as well.
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i ProGaMeR on the XboX 360 |
06-16-2010, 11:59 AM | #14 |
One cam is enough
130
Rep 6,801
You can pop that right out if you can get to it from the other side and, like a previous poster mentioned, heat it up a bit.
No paint damage would mean you could probably make it look like it never happened. |
06-16-2010, 12:17 PM | #16 |
One cam is enough
130
Rep 6,801
06-16-2010, 12:25 PM | #19 |
Dismembered Member
3583
Rep 9,213
Damn. I always wondered why the hell that shit was everywhere. Is there no way to fix that? LOL. Someone who isn't paying attention could get in an accident.
My delivery experience and beach photoshoot here. |
06-16-2010, 12:41 PM | #22 | |
Rep 27
yea retreads are cheap way to save the rest of the tire (the steel mesh and sidewalls), but basically glue on another set of treads. which tend to come off very often and then hit my car i'll try the heat gun suggestion tonight.. thanks... but its a good excuse to put an aero lip on |
