Can someone explain "torque" to me?
06-14-2010, 09:10 AM | #1 |
Rep 22
I have never been able to understand the meaning of torque or what it is or what it feels like. Any help would be great !
06-14-2010, 09:14 AM | #2 | |
5330
Rep 1,912
Very thorough definition from one of my favorite sites: http://www.straightdope.com/columns/...wer-and-torque |
06-14-2010, 09:29 AM | #4 |
20
Rep 402
think about torque as how big/strong the muscles are, and horsepower as how much the muscles can move in a given amount of time.
without good hp (ie torque high in the rev range) you won't get good acceleration. but without good low end tq, you will have to rev up the car to get anywhere... so there is somewhat of a tradeoff. |
06-14-2010, 09:30 AM | #5 |
483
Rep 10,309
Drives: A///MERICAN!!!
06-14-2010, 09:32 AM | #6 |
961
Rep 11,722
Diesel cars have such great torque. They can pull an elephant without a sweat, and yet maintain their fuel economy. what a trade off.
06-14-2010, 09:40 AM | #7 |
13
Rep 171
Personal Experience is the best teacher
Drive the 335d. Then you will understand.
2012 SG 740i
06-14-2010, 09:43 AM | #8 |
20
Rep 767
Think of it as ....Torque is how the HP is applied to the road. Torque is the measure of twisting power. HP is just straight on power. So you need HP to get the car to upper speeds and you need high torque to apply that HP to accelleration. So High HP = more speed and High Torque = quick take off power at low speeds. Simple version but gets the point across I guess. of course there is a ton of math to back it up....
06-14-2010, 09:49 AM | #9 |
148
Rep 1,728
Geek moment here so forgive me:
As per physics, torque is the derivative of acceleration. Therefor it is the rate at which you accelerate. Hence the break neck feeling... How does this relate to the per lb rating?...
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
06-14-2010, 09:58 AM | #10 | |
90
Rep 2,707
relevant to rotational torque. In another words rotational force at the pivot point if you have a 1 ft plank with X Lbs sitting the other edge.
zhpregistry.net - ZHP stats and free classifieds.
06-14-2010, 09:59 AM | #11 |
5330
Rep 1,912
Dunno, but if you get rear ended by a semi truck you will accelerate quicker than getting rear ended by a smart car so. At least I would think... someone test this out!
06-14-2010, 10:00 AM | #12 | |
just another bmw douche bag
195
Rep 3,640
(torque x rpm) / 5252 = HP
This is the formula for HP when torque is measured in lb/ft. HP is dependent on torque and RPM. How a car accelerates is directly related to the torque curve. I've always liked this article because it uses some good examples of how HP and TQ are applied in common cars. it's a bit old now, but it's still a very good read. http://www.vettenet.org/torquehp.html Quote:
06-14-2010, 10:08 AM | #13 |
Rep 22
Thanks thanks thanks to everyone for your quick responses! I have an 09 335i coupe and I can definately recall the headwhip you guys are talking about. Just always was curious of what torque was and never understood it. But thanks for finally getting an idea from you guys, really appreciate it!
06-14-2010, 10:16 AM | #14 |
Powered By 36DD
337
Rep 7,369
don't torque it too much or it'll snap?
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
06-14-2010, 10:31 AM | #15 | |
Rep 46
Torque
06-14-2010, 12:27 PM | #17 | |
Throbbing Member
43
Rep 1,433
Torque is a measure of force, not power. Anyway, others have already given the formulas and whatnot, but torque is the force the engine actually produces. Torque is what accelerates you. Torque is what a dyno measures. Horsepower is a calculated value which is based on torque and RPM. Assume you have an engine that makes a perfectly flat torque curve, say 300lb-ft across its entire RPM range. That means the engine at 6000rpm will be making twice as much power as it makes at 3000rpm, because the torque is constant. If you want to simulate what it's like to have an engine with high torque but less power (like a Diesel), accelerate at WOT but short-shift at 4500-5000rpm. You still feel a lot of acceleration (as long as your engine makes peak torque in the lower RPM's). You get a lot of acceleration but it doesn't last as long in each gear, vs. letting it run to redline before shifting. The thing is that you can take a high-revving, high HP (but low torque) engine and gear it for more acceleration. Think BMW M3. A shorter gear ratio acts to multiply torque at the wheels and increase acceleration. However, you cannot gear for more power.
2014 Tesla Model S 85kwh
Previous cars: 2011 335d / Deep Sea Blue / Saddle brown / sport / premium 2008 BMW 135i / 6MT 2002 Z06 Corvette Last edited by Thud; 06-14-2010 at 12:33 PM.. |
06-14-2010, 12:33 PM | #19 | |
245
Rep 4,494
the ft-lb measurement is only used in the US, otherwise it should be measured in newtons, as T=r x F
06-14-2010, 12:36 PM | #20 |
530
Rep 6,149
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
06-14-2010, 12:39 PM | #21 | |
Throbbing Member
43
Rep 1,433
Torque units always have a force component and a length component... Apply 1 pound of force to a 1-foot long wrench handle, and you're making 1 foot-pound of torque on the socket. If you're a wimp and can't push more than 1 pound of force, then you're fine as long as you have a 150-foot long wrench handle for your lug nuts!
Previous cars: 2011 335d / Deep Sea Blue / Saddle brown / sport / premium 2008 BMW 135i / 6MT 2002 Z06 Corvette |
06-14-2010, 12:43 PM | #22 | |
Dismembered Member
3583
Rep 9,213
My delivery experience and beach photoshoot here. |
