Brake Pedal Difficult to press
06-12-2010, 01:20 PM | #1 |
Rep 158
why is it that sometimes when i go to turn my car on it is very difficult to press the brake pedal? does the brake pedal and having a longer crank on the startup have anything in common?
there are times when i turn the car on and the brake pedal is very easy and goes down, and there are times when its stiff as hell.
AW F80 M3 - Niche - AWE - AFE - Bilstein - BMS
06-12-2010, 01:26 PM | #3 | |
Rep 158
after a certain time does the brake pedal become difficult to press on all 335i's?
06-12-2010, 01:45 PM | #4 |
45
Rep 1,754
brake booster pressure reservoir leak. It's a common problem. You can ignore it, or tell the SA about it next time it goes in for service.
06-12-2010, 01:47 PM | #5 |
Rep 158
ok, but i have 1800 on my car!!! the thing is a month and a half old... should i have them fix it? while i'm there should i have them take a look at the startups also?
06-12-2010, 03:54 PM | #6 | |
19
Rep 178
Getting mine fixed was quite a hassle. Don't let anyone tell you it's "supposed to go stiff", at least not overnight. Perhaps after a couple weeks it could lose some vacuum, but not hours. Mine once got so stiff overnight that I was unable to start the car, so I don't advise ignoring it (even if it's unlikely to get that bad for you). Anyway, they usually start by replacing the check valve, and that fixes most people. Mine took that, plus two more actual boosters and a visit from the BMW RTE before it was finally fixed once and for all. It has never gone stiff since. Good luck. Dave |
06-12-2010, 03:56 PM | #7 | |
19
Rep 178
Long startups are likely unrelated and probably HPFP, and you should definitely have that addressed. |
06-12-2010, 04:15 PM | #8 |
866
Rep 5,450
Yep, mine started doing it with like 4000 miles on the car - had it fixed in April and it worked for about 3 weeks and is just as bad now, will have it fixed again next oil change!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
06-12-2010, 04:30 PM | #10 |
Rep 46
http://www.bmwtis.com/tsb/bulletins/...p/B340607g.htm
(though, note this was just for cars up to 9/07) |
01-26-2011, 10:03 AM | #11 |
Rep 1
I have a 2011 335is purchased in June which has 4100 miles. The brake pedal is hard to depress when starting. It has happened about 7 times. The dealership has said they haven't heard about this occuring but to bring it in to be checked.
