E46 318i Mechanical Problems... Need Advice
06-07-2010, 09:39 PM | #1 |
398
Rep 9,156
Hey guys, sorry I don't know if this is the right place to post, I'm usually over on the 1addicts forum. My 2003 E46 318i steptronic has 101,000km's on it and as of today has been shaking and vibrating constantly.
It occurs mostly between 1,000rpm to 2,500-2,700rpm. The shaking is not in the steering wheel but in the car itself. In higher rpm's it seems fine. Also, the car is fitted with an aftermarket muffler exhaust which now makes a lot a more noise as though something is blocking it. It's at least twice as loud as before. The car constantly vibrates whilst it's at a standstill and even when it's in neutral. I've recently had the car in for a 100,000km service and spent quite a few dollars getting everything up to scratch so I'm confused as to what it might be. Sorry, I can't go into more detail, I'm not that mechanically sound so any advice would be appreciated. I know the E46 3 series run into quite a few problems with age. |
06-07-2010, 10:51 PM | #6 |
164
Rep 2,731
http://www.e46fanatics.com/
these crazy blokes may know a bit more about your problem. . . Could be a huge number of things, timing belt, alignment. . .
2006 E90 330i.
06-08-2010, 12:59 AM | #7 |
503
Rep 2,200
could be a bunch of things , sparkplugs? , a cylinder not working?, fuel injectors?
E9X Picture Game: 8 points: (High visibility jacket; Strip Club; Pizzeria; Sobriety Test; E9x dressed for Halloween, Billiards, Oil Change, Orange Cone)
06-08-2010, 01:24 AM | #8 |
Rep 68
do the rpm's fluctuate? It could be a bad Mass Airflow Sensor. I had one go bad on my e46 325xi and it caused rough running low in the rpm range but nary a whisper above 3,000. Have you tried pulling obdII codes from the ecu?
06-08-2010, 01:47 AM | #9 |
29
Rep 769
lmao u are always the first to shut someone down
[u2b]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/SMuXwdUS_Lc&hl=en_US&fs=1&color1=0x006699&color2=0 x54abd6"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/SMuXwdUS_Lc&hl=en_US&fs=1&color1=0x006699&color2=0 x54abd6" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/u2b]
06-08-2010, 08:04 AM | #11 |
68
Rep 896
Drives: 2021 X5
I had a similar issue and my revs would fluxuate... THis was on a 93 318i. It was the idle valve selenoid.
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black |
