Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Headlight shake?
      06-06-2010, 02:54 PM   #1
BlckX7
14
Drives: 2020 Blk BMW x7
Headlight shake?
I have 2010 e90 335i and the xenon headlights shake whenever I hit any kind of small bump in the road ( take note I live in NY and therfore a bump is hit every second). The beam of light shakes up and down which I have never had happen on any previous cars.
It seems as if the light bulb housing is loose.
Is this common? Am I just acting crazy?
      06-06-2010, 02:57 PM   #2
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Drives: F80 ZCP 6MT, R55 Clubman S 6MT
Are you sure it is not just the sensitivity of the bulb? Is this the first car you have had with xenons? Are your lamps adaptive?
My delivery experience and beach photoshoot here.
      06-06-2010, 02:58 PM   #3
335e92tx
ahat
335e92tx's Avatar
1036
Drives: Was '07-335e92 - Now '13-335IS
There is an extra support that BMW included in a tsb update for e92. But I don't think the lights on the e90 have the same support. I would just give it the visual once over - I found screws loose on mine even AFTER the dealership installed the support
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos.
https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8
      06-06-2010, 02:59 PM   #4
Alex@AKMotorwerk
Alex@AKMotorwerk's Avatar
208
Drives: 2012 AW F10 535i
could be the actual headlight housing lose behind the bumper. We've seen that a few times on new e90/e92's.
      06-06-2010, 03:05 PM   #5
BlckX7
14
Not the first car w xenons had an e36 w aftermarket xenons and a 08 5 series w stock xenons.
I do have adaptive healights . Is that the cause?
I mean this is more of a rattle shake up and down not a smooth movement.
      06-06-2010, 03:09 PM   #6
BlckX7
14
So maybe the entire headlight is loose? To fix would I just tighten the screws?
      06-06-2010, 03:14 PM   #7
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
yeah tried that. I am assuming that is the problem.
      06-06-2010, 03:18 PM   #8
Bagelfast
Bagelfast's Avatar
125
Drives: BMW
i had the same problem with my e90 lci 335i.... my e92 335i had the same problem i told bmw about it when i went into service they installed the extra bracket but it still did it a little.
      06-06-2010, 03:20 PM   #9
335iSSA
Poland
15
Drives: 07' E92 335i
I had a similar problem and took it to the dealer and I was told the automatic adjust mechanism was busted. They replaced the whole light. I lived with it for a few months b/c I figure it was just the Xenon which I hadn't had before. I actually figured out that it wasn't normal after having two loaners w/o the problem. Funny b/c the also left the support off when the installed the new light assembly and I had to take it back. Took me 3 trips to the dealer for them to get it right.
If they can't figure it out make them replace the whole assembly, it's really unacceptable.
      06-06-2010, 03:24 PM   #10
BlckX7
14
I also have lux h8 bulbs installed.
Should I take them out before bringing the car in?
Could they possibly give me a hard time w them?
      06-06-2010, 03:28 PM   #11
dcorn
77
Drives: 2008 E90 335i
I have this same issue. I thought it was normal because I've never had Xenons before and I figured the cutoff line was just super sensitive to vibration. Driving on bumpy roads, the headlights vibrate and bounce up and down quite a bit. Also, they were aimed very low when I first bought the car a month back, and I had to raise both of them up. I have adaptive xenons, could the adjusters be broken or messed up?
My mom has the same car pretty much and I don't remember her headlights being like that.
      06-06-2010, 07:45 PM   #12
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Just try tightening the screws in your housing, adaptive headlights should not be cause of them rattling as they work in conjunction with steering ratio; you mentioned they jiggle going over bumps and stuff. It should work! If not, there's always the dealership
      06-06-2010, 09:06 PM   #13
Alpine Whiteboy
Jerry's Fault...
Alpine Whiteboy's Avatar
175
Drives: 2013 535xi M-Sport SGM
I too have noticed this with my car. 2010 e92 335i X-Drive. I was wondering the same thing. I'm gonna have to check it out.
      06-06-2010, 09:14 PM   #14
k3m0-330i
k3m0-330i's Avatar
73
Drives: 08 335xi
2006 330i  [0.00]
it shacks because u hit a hole think man!!!
Current 2008 M6 e63 v10 6mt
Current 2012 e70 x5 35i -jb4
2008 335xi e92- Sold
2007 335i e90 - Sold
2002 Taig / Red / / / M3 - SOLD
      06-06-2010, 09:34 PM   #15
BlckX7
14
Excellent advice you should also follow it...
Think man!!! Did you mean to say shakes not shacks?
If it only happen when I hit a hole I wouldn't have posted about the problem. The headlight shakes on any kind of minor change in the road. I do realize if I hit a hole it would move.
      06-06-2010, 09:43 PM   #16
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Maybe he was being sarcastic LOL.
      06-07-2010, 06:33 AM   #17
dcorn
77
Mine shakes all the damn time, like over any sort of irregularity in the road, no matter how small. My gf said she thought I was high-beaming her when I was following her, and she drives a Jeep and we were on a pretty flat road.
Where exactly are these screws that I should tighten? Back of the housing? Behind the bumper?
      06-07-2010, 12:25 PM   #18
JJB
Drives: 2007 335i Sedan
My 2007 does it too. I see it if I make a not-so-smooth shift, or hit a bump in the road. Its my first car with Xenons, and I just figured it was normal. Now I wish I would have said something while the warranty was intact.
Oh well. I'll just pretend I didn't see this thread, and continue thinking its normal.
      06-07-2010, 12:28 PM   #19
Alan l.
Alan l.'s Avatar
5464
Drives: 2020 F95 X5M Competition
mine does the same thing since new 2009 E90. adaptive xenons.
      06-07-2010, 12:52 PM   #20
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
LOL.
      06-07-2010, 01:06 PM   #21
MRQturbo
20
Drives: 91 MR2 turbo....07 335i...
take the bulbs out if you bringing it to dealer unless you have a good relationship with them....
91 MR2Turbo....07 335i....
      06-07-2010, 01:11 PM   #22
aesfah
Max Powers
27
Drives: E90 330i
there's a TSB out there for this problem. Had support brackets installed at dealer. Still shaking. Got all new headlights installed. Much better - still a little shaking though.
