Installing amp on e90, any recommendations?
05-28-2010, 07:07 PM | #1 |
Rep 28
Hey guys, I want to install an Amp and put 2 12s in the trunk, nothing crazy a simple add-on to just improve the bass a little...
My thing is Can I tap the rear speakers in order to get a pre-out from the factory radio? Also will I be able to run a 800 watt or less amp on factory alternator? And last, which would be the best route to run the power cables to the trunk? I've done this on other cars but being as BMW makes everything so easy for only the guys at the dealers, i might be able to get some tips here on it. |
05-30-2010, 03:24 AM | #4 |
Rep 28
I have a 2007 335i, audio system... I will be using the stock system, I am just making the pre-outs from the rear deck speaker connection(splicing the speaker wire into an rca)... this should easily let the lows go into the amp and just give it enough kick.... like i said i dont want something crazy...
ohh and the "battery is in the trunk"... thanks for that!!! i havent really messed with the car at all.. so i havent gotten into it much... am currently rebuilding my bike so been focused on that mainly. to me the stock sound system isn't bad.... i would just like some more low bass kick on it... that is why i wanna do this. |
05-30-2010, 05:34 AM | #5 | |
221
Rep 2,339
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
05-30-2010, 09:01 AM | #6 |
2307
Rep 13,011
The 2007 335i has the Logic7 system, so it will need either a processor with up to 70W high level inputs or a LC6i before a processor for then to add an aftermarket amp.
The OP needs to go to a professional or he will damage his car/equipment. |
05-31-2010, 12:00 AM | #7 |
Rep 28
I have the stock system, it doesn't show a model or anything on it, besides BMW Professional I think it says that.. cant remember right now.
and about the amp I was looking into getting a Pioneer 760w GM5400T with 2 12s, haven't decided what brand the speaker or box style yet. PS. I did ask for your help guys and I appreciate all the tips and info on this, like i said I've done my systems on all my other cars, but everything on the BMW seems like a mission, and I've never worked on this car before. |
05-31-2010, 11:44 PM | #8 | |
Rep 28
Hey I looked up the LC6i, that will be the best result for what I want, as you mentioned I will need that to basically convert the speaker output into a pre-amp... Thanks I think that will be the answer I was looking for! |
06-01-2010, 06:30 AM | #9 | |
2307
Rep 13,011
06-01-2010, 09:37 PM | #10 | |
Rep 28
Thanks to everyone who put tips on the posts and recommendations! I will try to get a friend to take some vids or pics of the install and post them up! |
08-19-2010, 07:36 PM | #11 | |
Rep 17
09-14-2010, 04:50 PM | #12 |
Rep 28
Hey, its been a while.. and been doing a bunch of projects at work... well so far on the car, I have all the cables setup and getting the new speakers by the 15th of this month... I will put up a picture of the trunk once I have the speakers installed, for now my system is just sitting in the trunk.
09-15-2010, 02:11 PM | #13 |
Rep 28
Hey guys, I got the system done and its working very nice to my taste... its nothing crazy.. i get a nice deep bass that I like, the only cons so far is the tag which has a little rattling sense it is only held in by 2 screws... so that's an easy fix with some rubber spacers and adding the other 2 screws also...
Here are the pics.. I did all the installation by myself although am not any expert at this, but if anyone need I will lend a hand or w.e info I learn so far if needed by another "do things yourself guy" like myself.. |
09-16-2010, 11:52 AM | #14 |
Rep 10
Hey cubanpapi - I was just checking out the pics, nice work!
Would you mind detailing how you connected to your battery? Straight to 12V+ with a fuse? Where did you ground? My dealership is telling me there's no way to connect direct to battery (for a CarPC/power regulator in my case) and I don't believe them. Thanks! |
09-16-2010, 12:09 PM | #15 | |
289
Rep 3,201
http://www.e90post.com/forums/showpo...21&postcount=9 |
09-16-2010, 12:17 PM | #16 | |
Rep 10
09-16-2010, 12:53 PM | #17 |
289
Rep 3,201
I could poke fun at the dealership... but why are you even ASKING them, dude? They don't want anyone to screw anything up, so they say EVERYTHING'S impossible.
09-16-2010, 01:43 PM | #18 | |
2307
Rep 13,011
09-16-2010, 02:32 PM | #19 | |
Rep 10
1) I'm a dealer-sheep 2) the BMW is new (to me) and I'm afraid to break it 3) if #2 does happen I wanted to be able to blame the dealer But you're absolutely right... I shouldn't have expected much out of them. |
09-16-2010, 02:33 PM | #20 |
Rep 10
09-16-2010, 02:40 PM | #21 |
221
Rep 2,339
I grounded to the same bolt the battery grounds to. Depending on the location of your amp, that might be a bit far. There is also a grounding point on the driver's side of the trunk on the wheel well. There is a ground distribution block grounded to it and you can ground to the same point that the distribution block is grounded to.
09-16-2010, 07:01 PM | #22 | |
Rep 28
I connected the 12V+ and ground also right into the battery, I didn't use the adapter although it is very nice, now that I see the picture of it, but I chipped of a plastic side cover from another clip hatch that the batter cover has, and easily lets you put on it a 0-ring clip to it, as it already has a nut on it and all you have to do is put cut out about 7cm's or plastic tiny side panel of it. My cabling had been done for almost a month now, my speakers where the only thing that held me back till yesterday, and my car was in for service about 2 weeks ago at the dealer, the rep said that it was perfectly done correctly with cables being terminated to proper tips, and that this add-on would never be able to cause an electrical issue do to the fuse box preventing it... I knew that already, I only asked the guy how much of an amp can I put on this before I will need a cap... answer was anything over 1k watts... which is pretty much standard for when your going into that high of a system. |
