The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > WHY is cold startup jerky
      12-07-2006, 12:06 AM   #1
williamf
Audi Convert
Drives: Past: 335i Now: TTRS stage 2+
I know this topic has been discussed. Apparently, the new ECU flash reduces or eliminates this problem. Either I don't have the new flash or there is something else wrong.
NOW here is my question... WHY would the car be jerky at all? Ever? In my short 31 years I have had many cars ranging from an 84 Cutless to an 07 335i, none of them except for the 335i have ever had this kind of embaressing problem at startup and for the following 5 minutes. Does anyone know what the mechanical reason is for this well known problem? Engine warmup? Turbo warmup?
Am I being too demanding or should a 40K or 50K run smoothly all the time?
Three days after I got the car I brought it into the dealer and they said there was no problem and that I was just feeling the "adaptive transmission" adapt. Then, I did some research and it appears that was a lame excuse.
I love everything about my new 335i except for the first 5 minutes of every morning. That pisses me off.
      12-07-2006, 12:30 AM   #2
RaptorKTM
RaptorKTM's Avatar
236
Drives: 1 M Coupe
2011 BMW 1 M  [0.00]
how many miles do you have
      12-07-2006, 09:57 AM   #3
sdiver68
Expert Road Racer
59
Drives: 07 335i e90, 09 335i e93
You love the brake dust
Anyway, take it to the dealer and have the flash done. Your air-fuel mixture is not correct for the warm up period.
      12-07-2006, 11:05 AM   #4
Move.Over
Move.Over's Avatar
Netherlands
Drives: 335i
According to the TSB it affects cars build prior to Sept 15.
Mine doesn;t do it if I put it in DS mode while cold.
It probably has to do with the direct injection. Making an appointment today to have mine reflashed next week.
2007 335I, " Gray", Black Leather, Step, Comfort, ZCW, ZPP, ED - Oct 5, Dropoff Oct 9, redelivery Nov 15.
      12-07-2006, 12:15 PM   #5
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
I'll have to try that DS mode trick... my car actually fully cut out during accelleration yesterday, and it was not the traction control... it was like 20 degrees out, cold start... I have an appointment on the 18th, also getting a free after break-in oil change... once its warm, everything is dandy.
      12-07-2006, 12:24 PM   #6
335i=:)
27
Drives: 335i sedan-blk/blk-Poplar
Here in SLC, I live at the base of the mountains at about 5000 feet. It's routinely 15 degrees outside when I first start her up. I've also have noticed that my car simply starts and runs quite poorly when cold. I have started letting her warm up for about 15 minutes in the morning before I even take off. And then I don't drive faster than about 45mph for the first five miles in the morning. I think any car would have this problem when cold, and It makes sense it would be more pronouced when a car is new and everything is still so tight. Maybe it has something to do with the metal used on the turbo's? Maybe since it can handle such high temps it is challenged when facing such low temps? Just throwing that out there.....
      12-07-2006, 01:11 PM   #7
jundiz
Drives: E90 328xi sedan
Show this TSB to your dealer.
http://www.bmwtis.com/tsb/bulletins/...p/B124606g.htm
      12-07-2006, 05:55 PM   #8
SROC3
The limit of adhesion is my home.
SROC3's Avatar
1702
Drives: Like a Boss.
They give free after break-in oil changes???
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
      12-07-2006, 06:08 PM   #9
ctgazer
ctgazer's Avatar
383
Drives: a dilapidated ride
2006 e90  [0.00]
yah, mine doesnt do that...but ive got an e90 and got it in june 2005..GL with dealer
      12-07-2006, 06:11 PM   #10
williamf
Audi Convert
Originally Posted by jundiz
Thanks that is great. I am printing this and taking it to the dealer.
      12-07-2006, 06:14 PM   #11
williamf
Audi Convert
Socalm3,
Under 2000 miles
sdiver68,
Brake dust does not bother me. It seems every car I have ever owned had more brake dust than anyone else. I have become an expert at cleaning wheels quickly.
      12-07-2006, 07:09 PM   #12
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
it was part of my original deal, since i knew i would be doing it, i asked them to pick up the tab, and they said no problem.
      12-08-2006, 01:16 PM   #13
sdiver68
Expert Road Racer
59
Socalm3,
Under 2000 miles
sdiver68,
Fair enough. It bothers me a lot!
