Help?? RT Lowbeam Malfunction - Xenon Conversion
12-05-2006, 08:31 PM | #1 |
61
Rep 557
I did the conversion about 3 months ago and had no real problems up until 2 weeks ago. Initially if I started the car with the lights on, I had no error, however now it doesn't matter. The car comes up with an error and then will go away...5 to 10 minutes later it comes back and goes away after a few minutes and this keeps happening. Any ideas?? It's always the right one that comes up. As you can imagine an I-Drive DING can get quite annoying if you have hear it every 5 to 10 minutes.
Help??
'06 325Xi - Jet Black - SOLD, '08 328Xi - Jet Black, Coral, 6spd - SOLD, '07 328Xi - Jet Black, SOLD, '11 328Xi, Deep Sea Blue, Oyster/Black - SOLD
'14 428XI, Alpine White, Coral, MSport, Auto, Premium, Tech, Heated Seats/Steering, Drivers Ass, Drivers+ - On Order for ED |
01-03-2007, 11:01 PM | #3 | |
89
Rep 3,011
"Teach the ignorant. Ignore the stupid."
01-04-2007, 08:42 AM | #6 |
61
Rep 557
I checked the wiring and its all pretty tight....but I only seem to get this when it is cold out. I rarely get this message throughout the day, but only when it is under 45 degrees. The other night, the right bulb went out all together, so I turned the lights off and back on to see if it would help, and instead both lights went off! Not good at 2am on NYE night. Any ideas would GREATLY help!
And I would get the footwell module, but I like to have my high beam functionality which I don't believe has been fixed just yet. Thanks guys
01-04-2007, 03:20 PM | #7 |
Rep 249
Make sure the ground terminal of the xenon headlights contact the ground wire you added. As temperature decrease, the wires shrink, which may cause the xenon ground to lose connection with the ground wire. On my conversion, I spread out the wires so that theres a larger surface area for better connectivity.
What did the five fingers say to the face?
COOOOOLD BLOODED! |
01-04-2007, 04:15 PM | #8 |
61
Rep 557
hmmm..i guess it makes sense..ill give it a shot..thanks!
01-05-2007, 05:53 PM | #9 |
Rep 249
Explorer, is your problem resolved? Another issue may be where did you connected the new ground? I would suggest you connect the new ground to the old ground and not the body panel. Its less likely that you connect to the wrong panel + its a cleaner/shorter wire.
COOOOOLD BLOODED! |
01-10-2007, 04:26 PM | #10 |
61
Rep 557
Hey...I have it connected to the ground wire from the harness...I really only have problems when its cold and night....Its quite weird. In the morning, my lights are on..its still cold and no message...At night, it doesn't shutup!
01-10-2007, 08:57 PM | #11 |
53
Rep 464
I have been dealing with the same problem...thank god I have xenon fogs..so atleast I have plenty of light even after my xenons headlamps go out sometimes...
01-11-2007, 02:30 PM | #13 | |
pull my finger to get your kinder® surprise
148
Rep 10,455
you know he's got the same reply for every halogen->xenon conversion problem thread
