Someone help me drive a manual...
05-13-2010, 12:20 AM | #1 | |
Rep 17
Just received my 2009 335i MT coupe and I'm loving it but I do need some help...
I haven't driven a manual since a Z3 I had around 8 years ago, so I'm having a few problems in first gear. From a dead stop, I am having a very hard time getting the car through first without it jerking. Too few RPMs and it jerks, lugs, and possibly even stalls. Too many and it "kangaroos" and jumps and I end up going a little too fast intended. I'm looking for consistency and the only time I can really get it going without it jerking is if I ride the clutch and disengage it far too slowly, which can't be good for the clutch. Is it normal for MTs to have the jerk when getting it into first gear, lacking the fluid movement of ATs, or is it because I'm a noob? And technically, what is the worst thing I can be doing to my car/parts as far as wear and tear...? Too few RPMs and lugging/stalling, too many and jerking? Depressing the clutch too slowly and riding it? Quote:
05-13-2010, 12:25 AM | #2 | |
Hates Speed Limits
111
Rep 2,589
05-13-2010, 12:34 AM | #3 |
Rep 151
Congrats on your purchase...you shouldn't have too much of a problem if you've driven manuals before, but the 6sp on the 335s is a little interesting/tricky...the peak torque comes in at a really low rpm and can be a little tricky for even the most experienced drivers...the clutch delay valve also bothers some drivers
Try getting accustomed to when the clutch actually engages and catches the gear...do the no-gas method (in an empty parking lot) by slowly letting off the clutch while in first gear without touching the throttle to see when the vehicle will begin slowly moving forward...you'll have a better understanding of how to smoothly take off... In this car there is more of a chance for rough shifts in the earlier gears if you're too light on the throttle...the more you get used to the clutch, the smoother your shifts and take offs will be... |
05-13-2010, 08:09 AM | #4 |
5330
Rep 1,912
Yeah 1st to 2nd is a bitch even if you know what you're doing so don't be too concerned if you can't get a smooth shift 1-2. The rest should be pretty easy though.
05-13-2010, 09:04 AM | #5 |
20
Rep 902
if you've driven a manual before....it should still be the same...i find the car is very easy to drive......its not the car...its the driver.....lol...
91 MR2Turbo....07 335i....
05-13-2010, 09:20 AM | #6 |
36
Rep 564
Have you tried just starting in 2nd? 1st gear is very short, and I ony use it when making jack rabbit starts. Granted, I shift manually with an AT, but the gear ratios are the same as a manual.
05-13-2010, 09:32 AM | #7 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Remove the Clutch Delay Valve.
05-13-2010, 09:36 AM | #8 |
Rep 164
I didn't have a problem driving the car when I test drove my 330i but I have to admit its got one of the trickiest clutches of all manuals I have driven. I think the biggest problem is that clutch valve which interfers with your own control so as a result you get the worst 1-2 transition of all manuals. Some people use the modified valve to smooth out the ride. You will get used to it eventually just keep at it.
05-13-2010, 09:50 AM | #9 | |
17
Rep 431
In snow is fine because your tires slip instead of the clutch. Downhill is fine because it doesn't take lots of slip anyway. As a side note, did everyone see when Jeremy Clarkson started the corvette in 5th gear? "0-180mph..... in one gear!" |
05-13-2010, 11:13 AM | #10 |
14
Rep 468
Really it's going to take a lot of repetition and practice. I still have trouble from time to time in first making it smooth, my gf laughs at me but she has no clue how touchy the 335 is in 1st. It's much better than the piece of shit clutch on her IS250, god that thing has the dumbest timing ever.
05-13-2010, 11:19 AM | #11 |
71
Rep 801
Woolygimp, really look into removing the CDV (Clutch Delay Valve). It'll make your learning easier and your clutch modulation more consistent. Do a search here, it's a quick mod.
05-13-2010, 11:56 AM | #12 |
Rep 107
if your car is jerking your babying the the clutch, just let it go
2007 E92 328xi: Jet Black/ Black/ Aluminum|6MT/|Active Cruise|Xenons|Bluetooth|IPod|
Chuck Norris once kicked a horse in the chin. Its descendants are now known as giraffes. |
05-13-2010, 12:14 PM | #13 | |
117
Rep 327
if a girl can do it, you can do it (hope that gives you the willpower) ......be happy your not driving a 328, you wanna to talk about jerking... thing gives you whip lash it has such little power ! i found my 335 much more pleasant to drive. just take it for a long drive and youll get use to it.
'10 e92 335i m-sport; AW/Blk | ZPP | ZCW | NAV | Alarm | Logic7 19' 225s | JB+ | BMS DCI | CF TRiM | OEM PERF SHIFT/EBRAKE KIT sold: 07 e92 328xi & 07 e90 335i |
05-13-2010, 12:35 PM | #14 |
398
Rep 4,084
im going on almost a year with the car and the only way i can get a perfectly smooth launch is to release the clutch slower than i shoud, or as stated above, shift at a much higher RPM, at which theres almost no point to 2nd gear and ill go from 1st to 3rd.
also i'v found that going from 1st to 2nd as early as posible results in a much smoother shift. i'll launch in 1st, and my 2k RPMS i'll put it into 2nd. smooth as butter every time. I also think that BMW clutches are pretty resilient, and can take much abuse. iv heard stories about people abusing the hell out of the clutches and car is perfect.
7/18/09- I pick up my baby- 2009 E92 335i Xdrive, Space Gray over Coral Red. Premium Pkg, Cold Weather Pkg, M-Sport Pkg, 193Ms, Gloss Black grills, Custom Gloss Black Mirrors, Performance shift and E-brake boot, M3 spoiler, Euro fog switch, gloss black interior tim, Coco-Mats (red/black), H&R coilovers, 19'' Alufelgen SF-71s......
05-13-2010, 12:51 PM | #15 |
Rep 66
If you're getting into a situation where you gun it, try to let off, and the jerk puts your foot back into the gas - over and over (maybe this is what you mean by kangaroo?), you can try a trick I learned wheelin' my jeep on really bumpy trails...
Keep the right side of your foot against the tunnel (the hump, whatever you call it), and gently roll the left edge of your foot onto the gas pedal. That keeps your foot somewhat stationary, and will avoid the start/stop jerkiness. I've driven lots of sticks, and this seems to be the most temperamental. Good luck! |
05-13-2010, 12:57 PM | #16 | |
43
Rep 314
BTW, there were a few posts about shifting quickly out of 1st. Just be careful not to make the mistake of trying to make up time by jerking on the shifter from 1st to 2nd, ESPECIALLY when the tranny fluid is cold. Pull smoothly down from 1st, and when you're in between gears wait for the synchros, when they line up the linkage will slot in smoothly, it doesn't need to be forced. |
05-13-2010, 01:05 PM | #17 | |
29
Rep 1,309
Drives: Slow in the left lane.
Race car driving is like sex...all men think they are good at it. - Jay Leno
05-13-2010, 01:49 PM | #20 |
29
Rep 1,309
Never mind, I found the review.
05-13-2010, 02:36 PM | #21 |
55
Rep 3,606
Do NOT start in second gear regularly. You will wear out your clutch. Like the other guy said, try the no gas method. The lower the revs the less wear you will have on your clutch.
05-13-2010, 02:45 PM | #22 |
Resident Black Guy
251
Rep 2,302
the easiest way i was taught was let the clutch up slowly so u can feel it grab (thats without pressing the accelerator.) if that makes sense to you.
