question about 335i steptronic
05-11-2010, 04:42 PM | #1 |
Rep 158
ok so here is the deal, i am used to driving manuals and my last car was an e46 SMG II....
due to some physical ailments, i am not able to drive manuals anymore for long periods of time, so i decided to pick up a 335i m-sport with power kit steptronic. the question i have is that when i am driving the car in manual mode (not in sport), how can i keep the car in manual without it shifting into automatic by itself? if anybody can help me out it would be appreciated. thanks.
AW F80 M3 - Niche - AWE - AFE - Bilstein - BMS
05-11-2010, 04:49 PM | #2 |
12
Rep 237
Drives: e90 335i, f30 330i
If you are just in D, you can shift using the paddles but it goes back to automatic. Just move the lever into sport and then shift using the paddles. Now, your in manual until you move the lever again. Or if you don't have paddles shift using the stick, you get it.
05-11-2010, 05:22 PM | #3 |
Rep 158
yea, but when its in sm mode, it drinks gas like there is no tomorrow. there is no way to keep it in manual when its in D? thats kind of stupid.
05-11-2010, 05:24 PM | #4 |
12
Rep 237
Thats true, if you keep it in S automatic then it eats up gas. But once you shift into manual mode, your in control of the gears and can shift when you want. Its not shifting itself anymore, so you can shift at low rps to save gas. Its not like it stays automatic sport mode.
05-11-2010, 05:26 PM | #5 |
363
Rep 5,873
Drives: m
Sport mode keeps the rpms up. But manual mode lets you change gears whenever you want and the trans will not change gears for you unless you get into a danger zone.
05-11-2010, 05:31 PM | #6 |
1646
Rep 4,878
When in sport mode, it won't shift into 6th gear on the highway, that's probably why you're getting the fuel consumption. Just use the paddles, and it's fine.
05-11-2010, 05:53 PM | #7 |
Rep 158
awesome.. thanks guys... i appreciate it.
so the only difference between d and s is that the s leaves the rpm's higher, so if i mash the throttle whether in d or s it will have the same fuel consumption? i remember in my e46 m3, the sport button opened up the throttle body which lead to poor gas mileage, its not the same with this?
05-11-2010, 06:37 PM | #8 | |
122
Rep 6,594
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
05-11-2010, 06:58 PM | #9 |
Rep 158
is there anyway to make the shifts faster? like some sort of software update or anything?
05-11-2010, 07:05 PM | #10 |
122
Rep 6,594
Nope, it's not adjustable like the DCT. It is what it is.
05-11-2010, 07:39 PM | #11 |
Rep 158
i guess thats fine.. its not too bad as it is.... very smooth. i am still used to my old SMG II... big difference.
05-11-2010, 07:44 PM | #12 |
13
Rep 110
05-11-2010, 07:55 PM | #13 |
Rep 158
well coming from an smg II m3, the shifts for that car were pretty damn quick. i'm not saying the shifting is slow for the step... i was just curious if there is a way to make it faster.
