Strange hesitation and shutter issue at high speeds. (HPFP?)
05-11-2010, 02:53 PM | #1 |
Doctor of Journalism
28
Rep 352
In the past few weeks I have noticed a strange issue with my 335xi sedan at high speeds. I am cruzing on the highway at or above 65mph and I am in 6th gear and giving the car about 1/2 throttle. (Just enough to keep my speed and stay in 6th). If I back off on the throttle and then give it gas again I will feel the car hesitate a small amount and shutter 3 or 4 times very slightly as my speed increases. (This is VERY subtle but after driving 40K miles in this 335 and another 60K on my last 335 I no what feels unusual.) This ONLY happens on the highway under these conditions and only happens about 50% of the time. I am taking the car in tomorrow to be looked at by the dealer but I wanted some opinions before I went in.
Could this be a HPFP issue? Intake maybe? Carl |
05-12-2010, 10:53 AM | #2 | |
Rep 51
I just got the car back from the dealer yesterday, and they just flashed the ECU with a newer version of software. So far, after 1 day, I have not had the issue nor the long cranks on cold start which was my other issue. I can report more after a couple of days with the car, but initially it seems to have fixed the issue. Ron |
05-12-2010, 11:37 AM | #5 |
Rep 66
Mine shakes if I'm crusing at that speed then floor it to pass.
I'm taking the car in next week, so I'll let you know what they say. Service Advisor thinks perhaps HPFP, but we'll see. |
05-12-2010, 11:52 AM | #6 | |
Been there, wrecked that.
18
Rep 547
-Brian
~199K miles. I -still- don't fear my 335i. |
05-12-2010, 12:03 PM | #7 |
28
Rep 352
It looks like I was right about it being related to the hpfp. When they checked the ecu there were 5 or 6 shadow codes related to "low fuel rail pressure" or something like that. It was not enough to throw a code I could see but it did log in the ecu.
So has anyone noticed any performance issues after getting the new software? |
05-12-2010, 03:12 PM | #8 | |
Rep 51
No performance benefits other than the lack of shuttering on load between 2k and 3k rpm. There are additional menu options in the idrive and a revised warning when the navigation system fires up. My car had 6 injectors, cal 1 coil and plug replaced before this update was done. Still on the original pump. 17k miles. Ron |
05-12-2010, 03:27 PM | #9 |
One cam is enough
130
Rep 6,801
I have that same "pulsing" hesitation while cruising.
According to the dealer, it's nothing. Just like a whole bunch of the other non-issues I seem to have with this car. |
05-12-2010, 07:04 PM | #10 |
Rep 51
Well. So much for the software update fixing everything. Still no long cranks, but the hesitation came back again today. Since someone on here mentioned traction control, I disabled it with the dtc button and the problem recurred right after.
Ron |
07-25-2010, 09:25 PM | #11 |
187
Rep 1,103
Been looking for something that describes what I'm experiencing. The things mentioned in this thread seem to describe what I'm feeling also. I feel the hesitation in 6th at highway speeds while maintaining speed. I also feel some hesitation in 2nd gear under WOT almost as if I letoff the throttle a bit and reapplied it repeatedly like a stuttering.
Wondering if this is related to my HPFP. |
07-25-2010, 11:37 PM | #12 | |
28
Rep 352
The shop foreman said that the carbon buildup was keeping the valves from closing completely creating the strange hesitation and bucking I was feeling. If your experiencing this same issue and have a good amount of miles on the car, have them clean the intake. The car is 99% better now. CL |
07-26-2010, 09:23 AM | #13 | |
187
Rep 1,103
Thanks |
07-26-2010, 01:18 PM | #15 |
189
Rep 609
I have a similar pulsing when cruising around 60/65 mph, but I just had my 4th HFPF replaced and new spark plugs, but still have the pulsing feeling???
2019 Z4 sDrive 30i Msport,
Previously owned BMWs, 2014 428i Msport, 2008 335i Coupe, 2007 328xi sedan, 2002 325i sedan 1996 318ti (loved this little car) |
07-26-2010, 10:11 PM | #16 | |
Rep 66
07-27-2010, 12:13 AM | #17 |
187
Rep 1,103
Those of you that had the issue resolved with the cleaning of the intake. Did you just complain about hesitation to the dealer or was the car actually throwing any codes. If it was just the hesitation did the dealer try to replicate the issue or did they just investigate it for you.
Just trying to figure out what I need to say to the SA exactly to get this resolved. This thread has been helpful as it seems to be the issue I'm experiencing. |
07-27-2010, 12:56 PM | #18 | |
Rep 66
Finally I had to say - you've changed plugs twice in the last few months. you've changed vanos solenoids twice in the last few months. These might be bad - but something else is making them bad. Please keep my car until you get it right! And they did. It took a month, but they got it. It sounded like this dealer wasn't that familiar with the problem. They had a BMW field engineer in twice to look at it before they came to this conclusion. Apparently a lot of labor is involved, so maybe they don't want to jump right into carbon scrubbing. I suspect as more N54s approach 50K, the dealers will get very familiar with this issue. |
07-28-2010, 04:46 PM | #19 |
24
Rep 345
I recall seeing a video on how to clean your valves on E90 at one point - someone idling their car and spraying the cleaner directly into the intake hose. Too lazy to search.
The issue if I recall is that with direct injection the gas no longer washes the valves as it does with port injection, so carbon and gunk can build up over time. On the stem/top of the valves. Probably one of the engineering data points used by Lexus in their DI engine, which does both port and DI. |
08-11-2010, 09:26 PM | #20 | |
16
Rep 144
Having the same issue with my car - looks like I'm not the only one.
http://www.1addicts.com/forums/showthread.php?p=7815964 Quote:
08-11-2010, 11:19 PM | #21 | |
Rep 66
