Is it me, or does this service quote from an independent shop seem a little steep!?
05-11-2010, 02:49 AM | #1 |
31
Rep 155
Hello folks,
I recently purchased a 2006 bmw e90 330i. It currently has 70k miles and needs some maintenance work. I just got an email back from a highly reputable independent bmw performance shop in my area with a quote on the maintenance work needed. I'll leave the name of the shop anonymous as thats not what's important to the story. Anyways, here's what they quoted me as follows. - flush brake fluid: $164.10 - change diff. fluid: $120.52 - flush coolant: $184.91 - Change spark plugs: $354.17 - change gear oil: $120 (car is a manual transmission) TOTAL: $944.22 Is it just me, or does this seem pretty steep for some basic maintenance work??? Like I said, they have a strong reputation and seem to be a very popular shop. Though please however share your thoughts. I'd really like to know whether I'm getting scammed or if this is a pretty normal price for the listed work on an e90 3 series through an independent shop? Thanks in advance -Will |
05-11-2010, 03:21 AM | #2 |
Rep 93
The price doesn't seem that far off. Also, if the shop has a sterling reputation and you've personally seen they take excellent care of their customers cars, I'd say go for it. I'd also recommend getting estimates from other shops and compare them to the first shop and see if they're way off or not. It's hard bringing a new car to a shop you're unfamiliar with. Good luck!
Cheers |
05-11-2010, 03:31 AM | #3 |
1705
Rep 14,829
Never serviced a BMW out of free maint as my car is 3 1/2, but those prices seem about quadruple what a Nissan would cost, so if a BMW is double that of a Nissan, yes, they sound steep. But then again, I didn't get the definitive, but one guy said $1700 for front brakes on a 335, and another said $900, so prices in general sound steep....
05-11-2010, 04:02 AM | #4 | |
103
Rep 2,783
D I Y |
05-11-2010, 04:43 AM | #5 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
at least do your own plugs. it will cost you the price of a BMW plug socket. and about 2 hours of fun, w/ you getting to know your engine. you can do it.
05-11-2010, 07:22 AM | #6 |
3572
Rep 10,352
Sounds about right for Calif. the problem is all the crap they ahve to get through to do the work (Coolant and Plugs esp). On the pluse side you'll probably never do most of that work again.
05-11-2010, 07:33 AM | #7 | |
117
Rep 327
BMW spark plugs are about 22$ a piece. $132 dollars in parts and should cost about 1.5 - 2 hours in Labor tops. They are charging you over $100 per hour, i would definitely attempt to negotiate or ask for a discount, they is definitely room for them to knock off a couple bucks. heres our prices (and were a dealership) so you can compare - - flush brake fluid: $139.95 - change diff. fluid: $229.95 (but this is a flush, not drain and fill) - flush coolant: $189.95 - Change spark plugs: $237.00 - change gear oil: $99.95 hope that helps. good luck !
'10 e92 335i m-sport; AW/Blk | ZPP | ZCW | NAV | Alarm | Logic7 19' 225s | JB+ | BMS DCI | CF TRiM | OEM PERF SHIFT/EBRAKE KIT sold: 07 e92 328xi & 07 e90 335i |
05-11-2010, 07:37 AM | #8 | |
34
Rep 221
Ok, here is what I think of this:
Spark Plugs: Purchase a BMW Spark Plug socket (about $15 plus shipping online) and 6 BMW plugs ($18 each at Tischer). Follow the instructions HERE. Savings: $230 The differential fluid and gear oil changes can be done at home, too. Sometimes people don't have jack stands or ramps, or they just don't have anywhere to take the used oil to, so I can understand taking it in for service for these two (the same with the coolant flush). |
05-11-2010, 07:59 AM | #9 |
47
Rep 1,160
Spark plugs you can deff do your self and safe some money other than that the other work seem to be at a decent price.
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
05-11-2010, 08:04 AM | #10 | |
25
Rep 374
05-11-2010, 08:57 AM | #12 |
156
Rep 1,046
I think he was saying all the old fluid will have cycled through the Master Cylinder allowing it to be replaced through the process.
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport |
05-11-2010, 09:06 AM | #13 | |
I ask the questions you're afraid to ask.
44
Rep 2,489
The "turkey baster method" does not remove moisture from the system. Remind me not to buy a car from the fellow who posted this "advice." |
05-11-2010, 09:16 AM | #14 | |
156
Rep 1,046
05-11-2010, 09:19 AM | #15 |
25
Rep 374
It won't though, it will just stay at the ends of the lines / in the calipers.
05-11-2010, 09:19 AM | #16 |
138
Rep 2,731
baster method works with power steering fluid because that fluid is constantly recirculating, there is a return line. it would not work on brake fluid, for this you are best off removing all 4 wheels and just doing a bleed/flush, very simple if you follow directions. even if you buy a bleeder kit you would still come out ahead.
i would DIY all of it, coolant is probably biggest pain in the ass because you have to get under the car and unhook hoses from the waterpump but well worth the savings. |
05-11-2010, 11:11 AM | #17 |
61
Rep 938
Bring your car down to Orange county and I'll change the plugs for free!. Probably cost you $50-60 bucks for the parts. $350 is way too much for plugs. The other quotes don't look too bad.
05-11-2010, 11:31 AM | #19 | |
1705
Rep 14,829
In the pecking order imho Nissan > Hyundai, and if a Nissan is cheaper to maintain, that's even more power to them. |
05-11-2010, 12:18 PM | #21 | |
Chicks dig wagons!
43
Rep 1,375
Drives: 2009 E91
Location: Where you can see through the people, but not the air (i.e., Los Angeles!)
E91 Montego Blue gray leather burl walnut , Idrive, PDC, Logic7, CA, Sirius, xenons, 6FL, ZPP, heated seats, 17" tires.
4, 8, 15, 16, 23, 42 |
05-11-2010, 12:32 PM | #22 |
254
Rep 1,391
Reputable indy shop that specializing BMW charge pretty close to BMW dealer in my area. Hard to make decision sometimes, I'd like to maintain relationship with dealer for (once in a blue moon) "goodwill" out of waranty work from BMWNA so most of the times I go to dealer but also DIY if I can do it.
