'squish' sound from tires or suspension??
05-09-2010, 10:54 PM | #1 |
40
Rep 720
I just noticed this while I was driving with my windows down..
There's some 'squishing' sound coming from the tires or suspension when going on a rough road or bumps. When I hit a bump for example, it would 'squish' at the same time.. It almost sounds like air is coming out of the tire or something.. I can only hear it when windows are down. I'm thinking it might be the suspension. Is it normal? |
05-09-2010, 11:36 PM | #5 |
43
Rep 358
I wouldn't worry about it.. it's just the oil moving around in your shocks. It'll probably go away from my experience, but at any rate it's nothing to lose sleep over.
2006 e90 330i | Black/Terra | 6MT | ZSP | ZPP | ZCW
05-09-2010, 11:42 PM | #7 |
Where'd my VTEC go?
481
Rep 6,067
Normal sound that shock absorbers make.
05-09-2010, 11:42 PM | #8 |
Rep 151
I get the same noise coming from my driver's side wheel going over speed bumps...it happens no matter how slow I go over them...I was thinking had to do with the shocks or some other component of the suspension...any ideas?
05-10-2010, 09:02 AM | #10 |
27
Rep 959
If it's really loud (you can hear it with windows up) you may need your front bushings replaced, I did. There's a TSB for that.
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC |
05-10-2010, 12:00 PM | #12 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
normal
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
05-14-2010, 11:39 PM | #14 |
Rep 71
I started hearing this too. But only on my front passenger side which is coincidentally the same side that had a tire replaced. So I guess it's normal and I don't need them to double check their install?
