oil change problem.....cant fix it - help!
05-08-2010, 08:43 AM | #1 |
22
Rep 176
ok, went to do a simple oil change.
when done, i checked the oil level, it was half. i drove it for 30minutes, it went to miniumum and add 1Q of oil. So I went to add more, the oil sensor shows maximum now. turned the car off and on again. still at maximum. I go to turn it on again after 5minutes to drive it, the oil gauge shows 3/4 to max only. this morning it only showed half full. What is going on?? |
05-08-2010, 12:11 PM | #3 |
138
Rep 2,731
so how many quarts total did you put in there? provided there are no leaks whatever you put in should still be in there.
with that....look for leaks, since you only pulled the drain plug you could just remove the trapdoor for a day or two so leaks will hit the ground and be visible. you might want to pull the filter and make sure it's not crush and is seated correctly, not sure if that would cause the strange readings or not but worth checking. a blockage might cause strange readings, i always make sure to remove all the foil from the cap by hand before i go pouring it in the engine just in case a piece comes off and gets in my motor blocking passageways. as long as there are no leaks and no blockages, if you know you put enough oil in there running the motor should be fine. i would let it warm up and try to check it consistantly under the same conditions to get a good baseline reading. |
05-08-2010, 07:29 PM | #4 |
253
Rep 7,089
Drives: '06 AW 330xi
Are you getting these reading on a level surface? You should be.
05-08-2010, 08:46 PM | #5 |
173
Rep 3,415
Oil change:
Open oil filter cap. Open drain. Let oil drain out. Suck and remaining oil from the filter housing. clean and then replace the filter. Close drain bolt. Add SEVEN (7) QUARTS of BMW oil. You're finished. |
05-17-2010, 09:09 PM | #7 |
Rep 25
How many quarts did you use for the oil change? If it's 7 then you have a defective oil level sensor. If you're not sure then drain the oil out and measure it.
Be nice to have a dipstick eh? how silly..... |
