Rear Vibration
05-07-2010, 06:50 AM | #1 |
12
Rep 219
Rear Vibration
I have a vibration in the rear. 06 330i Non-sport package. Had the tires (stock 17" 159s with Conti RFTs) balanced/rotated recently and it didn't get rid of the vibration. Vibration is in the rear, no vibration in steering wheel just can feel it in the seats. My kids say the car vibrates when they sit in the back. It's more noticeable driving on new asphalt roads. Speed doesn't seem to make a difference. I can feel it at slow and fast speeds. Is this just the BMW "feeling the road" sensation or could I have a suspension or rear axle problem. Any thoughts would be appreciated.
05-07-2010, 06:51 AM | #2 |
Rep 78
Vibration in rear? Enjoy it.
Last edited by hayabusa55; 05-07-2010 at 06:54 AM.. Reason: On a serious note, are your tires worn? I had some bad tires where the noise and vibration became unbearable. |
05-07-2010, 07:58 AM | #4 |
138
Rep 2,731
since you are on stock 17's, square setup i assume, i would put the front on the back, and the back on the front.
if the vibration moves up front then it is a problem with your wheels/tires and you need to get them rebalanced, i would suggest finding a place with a "hunter road force balance" machine. it will find out if the rim or tire is not true and it will have the tech position the tire on the rim so that the eccentricities cancel each other out. if after switching the tires front to back the vibration is still in the back, then you have a warped rear rotor or some kind of weird suspension issue, not sure what else it could be. first step is to switch the wheels front to back to isolate the problem. get back to us. also check those rear wheels and see if the weights are still stuck on the inside, they can be on the outer and inner edge so look for two sets, if you see them can you tell us how much weight there is. should be stamped on each weight. |
05-07-2010, 09:07 AM | #5 | |
12
Rep 219
05-07-2010, 11:14 AM | #6 |
138
Rep 2,731
RFTs ride like shit and certain brands cup easy, after hearing all that it could be cupped tires. if the tire has uneven wear like that a balance won't fix it.
if you had them rotated and the problem was still there then both tires are cupped or it's something with your rear drivetrain or suspension. is this a vibration like something out of balance or just road noise? |
05-07-2010, 12:13 PM | #7 | |
12
Rep 219
Bought the car used (non-CPO) from a non-BMW dealer. (I know, big risk but price was right.) The carfax had nothing on it other than scheduled routine maintenance and two entries about tire replacement (I thought it was flats getting replaced.) 01/20/2007 - One tire mounted and balanced 04/18/2008 - One tire mounted and balanced So, dealer is out because no warranty or CPO (57k miles). Should I just take it to my local garage (they have a roadforce balancer) and pay the money to let them figure out if it actually is a problem or should I just live with it? Anyone else with a 330i have a similar problem? |
05-12-2010, 09:37 PM | #8 |
24
Rep 472
I have the same problem but in the front. It's a slight vibration in the steering wheel. I had the tires rebalanced by the dealer but it was still there . It was more prevalent when driving in the 65+ range.
The only thing I could think that may be causing it are the RFTs. I switched out the wheels with a set of 18" VMRs and the problem went away. I guess the dealer said they rebalanced the stock wheels.. Obviously not
2006 330xi
BMW, please get rid of the RFT's and give us a spare tire! |
05-12-2010, 09:42 PM | #9 | |
138
Rep 2,731
