TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Problem with Jerky Stops - 2007 335i
      05-05-2010, 10:20 PM   #1
johnny_boy
Drives: 2007 335i
I am having an issue with jerky stops in my 2007 335i. Almost every stops I come to, right before the car stops, the car jerks forward like someone tapped my rear bumper. At first, I thought this was only when the engine was cold, as I only drive very short distance back and forth to work (less than 5 miles), but it still does it even when the engine is fully warmed up. When cold, it is every stop. When warm, maybe 70% of the time.
Anyone else still having these issues? Search seems to bring back posts from 2007/2008, but not much more recent ones, so maybe the recent models do not have this issue? I am the second owner, so I am not sure if this was there before, but I have noticed this for past few months.
I am assuming this is the soft stop feature. Anyway to disable this? This shows up on both D and DS mode. I think it even does it when I manually downshift coming to a stop.
I took it to the dealership twice and:
- the first time, they checked the transmission fluid (OK), and then reset the computer. It was good for a day, but then the jerk came back
- the second time, reprogrammed the computer to the latest, and they raised the issue with BMW, and they denied PUMA case saying this is within the working parameters of the operations of the car
I am not sure how this could be “normal”? If I reset the transmission learning thing (foot off the brake, push “start”, hold down the gas pedal for 60 seconds), then it will not do this for a short while, but then it will come right back within a day.
I can deal with this if it happens every once in a while, but almost every stop is a bit ridicules.
2007 335i
      05-05-2010, 10:31 PM   #2
smallseafishie
110
Drives: AW 07 e92 335i + AW 11 X5 35d
2007 E92 335i  [0.00]
I believe there was a problem with hill assist interfering with the way this works.
I believe the new software disables this feature? I forget. Search for hill assist and brake jerk or something?
      05-05-2010, 10:56 PM   #3
Longhorns159
Longhorns159's Avatar
Drives: 06 BMW 325i
Location: Texas Born n Raised...currently living in Cincy, OH
its normal, it happens in my car all the time..just a result of the hill assist feature
      05-05-2010, 11:22 PM   #4
jrsniper12453
jrsniper12453's Avatar
13
Drives: 335i
I'm 97% sure if you report this to the dealer they will update your software and the problem will go away.
2007 335i, Space Gray, Black/Alum, Sports, Prem, CA, Navi, iPod
      05-05-2010, 11:29 PM   #5
jrsniper12453
13
Drives: 335i
SI B 24 06 06
Automatic Transmission October 2006
Technical Service
This Service Information bulletin supersedes SI B24 06 06 dated August 2006.
designates changes to this revision
SUBJECT
A Slight Bump is Felt Shortly after the Vehicle Comes to a Stop
MODEL
E85 3.0 and 3.0si with the GA6HP19Z transmission produced up to 07/2006
E90, E91 All with the GA6HP19Z transmission produced up to 09/2006
SITUATION
A slight one-time bump is felt shortly after the vehicle comes to a stop.
CAUSE
This is due to the design concept of "NIC", or Neutral Idle Control. This gearbox feature uncouples the torque converter whenever the vehicle is stationary, gearbox oil temperature is between 20°C and 120°C, and the brakes are applied. By disconnecting the torque converter the load on the engine is reduced to a minimum. Please explain this feature and its operation to the customer.
CORRECTION
For the E85, revised EGS software is available with Progman 23.0 or higher.
For the E90, E91 revised EGS software is expected in a future release of Progman. Until that time, on a customer complaint basis only, this feature can be deactivated as described in the procedure below.
PROCEDURE
E85 – On a customer complaint basis only, reprogram the EGS module with Progman 23.0 or higher. It is not possible to deactivate this feature using the retrofit option on the E85.
E90, E91 - On a customer complaint basis only, perform the Retrofit - "Converter lockup clutch" using Progman 23.0 (Target Data status: E89x-06-09-520) or higher. Follow the "Retrofit" procedures as outlined in SI B09 05 01.
      05-05-2010, 11:56 PM   #6
johnny_boy
Drives: 2007 335i
I did see that SI before, that is why I asked the dealer if my "computer" was up to date, and he said yes. But the problem still shows.
Is this a separate procedure than updating the "computers"?
2007 335i
      05-06-2010, 12:32 AM   #7
jrsniper12453
13
Drives: 335i
nope
      05-06-2010, 12:38 AM   #8
mkiv
2JZ
63
Drives: 16 G500
i have the same problem.
      05-06-2010, 12:47 AM   #9
jopa489
122
Drives: Anything with Wheels
Are you sure they actually did the update and were not just BSing? Updates on these cars are very complicated and can take several days. The SIB posted above is right on.
X7 LCI // Incoming
C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo
      05-06-2010, 01:17 AM   #10
chromisdesigns
45
Drives: 2008 BMW 335i sedan
AHA! So it's NOT a loose can rolling around in the trunk, after all! Seriously, I'd heard of this NIC issue, but hadn't connected it to the thump I get pulling into the garage...thanks for describing it so clearly. Now I know what's going on.
I don't think I'm going to bother with getting it disabled. As someone pointed out, reprogramming can take a day or more, and there is always something that gets reset or missed or set wrong or...better leave it well enough alone.
Thanks for the info, though!
      05-06-2010, 06:19 AM   #11
dcorn
77
Drives: 2008 E90 335i
One more reason to buy a 6mt
      05-06-2010, 02:21 PM   #12
johnny_boy
Drives: 2007 335i
They might be BS'ing on this. I will actaully ask for the print out of the details of the car, so I can verify.
BTW, the SI thing posted up there seems to indicate that the bump is felt AFTER the car has stopped, but I feel it RIGHT BEFORE the stop. So I am not sure if this is the same issue or not.
Sometimes the jerk is very smooth, and I have no issue taking that as a "normal" behavior, but most of the time, it feels like a decent tap on the rear bumper by another car.
2007 335i
      05-06-2010, 02:23 PM   #13
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Drives: F80 ZCP 6MT, R55 Clubman S 6MT
Happens to me too. Only rarely, though. Seems normal.
My delivery experience and beach photoshoot here.
      05-06-2010, 04:32 PM   #14
ragingclue
One cam is enough
ragingclue's Avatar
130
Drives: VF
I used to have the same problem, but after already coming to a stop. That one was the NIC. I don't think the NIC will give you issues while you're still coming to a stop, but I may be wrong on that one.
      05-06-2010, 04:43 PM   #15
fdriller9
253
Drives: '06 AW 330xi
2006 330xi  [6.44]
If you read the SIB more carefully, it says that there is not fix for E9x vehicles yet. The solution is to disable the NIC.
      05-07-2010, 05:59 PM   #16
johnny_boy
Drives: 2007 335i
That was dated October 2006, so it has been 3.5 years since. No updated SIB? Is that the latest and so I should ask this to be done as this fix is not part of the regular update it sounds like?
2007 335i
      05-07-2010, 06:35 PM   #17
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
I can confirm the same thing happens with my car and I have a 6MT. Its not just with AT.
Mine is bone stock 2008 335i E90. The software in the car is still the original one from the factory.
When I slow down to a stop, right about when the car is about to get to a full stop, it "lurches" for a second, then comes to a full stop. It feels like the brakes gave in at the last second and then they clamped on again...
      05-07-2010, 07:48 PM   #18
johnny_boy
Drives: 2007 335i
That is exactly what I get as well. How often does this happen? Mine is almost every stop. Have you approached the dealer about it?
2007 335i
      05-07-2010, 09:42 PM   #19
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
I don't mean this in a bad way at all: is this your first BMW?
The only reason I ask is I've noticed many people had issues with the brakes being 'touchy' when going less than 5 MPH.
Not trying to diminish your issue, just trying to understand the perspective.
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport
      05-07-2010, 09:54 PM   #20
chromisdesigns
45
BMW's do have "real" brakes, unlike a lot of other cars. But this problem is well known to E90 drivers. It's not his imagination.
      05-07-2010, 09:56 PM   #21
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
I wasn't necessarily saying it was made up. Just trying to understand the balance between what he's seeing and what the dealership is seeing and finding. He's probably right about it. I just know sometimes it is simple things, ya know?
      05-08-2010, 12:28 AM   #22
ShinyRedCar
Drives: 2006 BMW 325i
I am having an issue with jerky stops in my 2007 335i. Almost every stops I come to, right before the car stops, the car jerks forward like someone tapped my rear bumper. ... This shows up on both D and DS mode.
I only get this when the car is in DS mode.
Jeff
