HPFP agitation theory
05-05-2010, 09:35 PM | #1 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
I have 36k miles on my original pump. I have seen people here on the forums that are on the second car after a lemon replacement and still have HPFP issues! On the other hand, I have also seen people that have purchased lemon'd HPFP cars without a hiccup!
Makes me wonder if it's something else that an owner may doing to agitate the problem. There have been discussions about gas quality and what not but through the polls it seems as if it's wide spread regardless of gas brand. My theory is that some people are starting their cars shortly after they first unlock it (not saying they shouldn't, as the car should work fine regardless). If you ever sit in the car after it has been parked a while, you will hear a whine of the fuel pump priming after unlocking. The reason I have come to this hypothesis is that I remember reading a post a while back that said if they unlocked their car, and waited a while (wait for nav to start or something) prior to starting the car, it would less likely have long cranks. I also have 2 friends with 335i's that have had HPFP issues. One has Comfort Access and starts the car as soon as they get in. The other unlocks his car right at the door and gets in and starts the car immediately as well. 2 other friends and I have not had any HPFP issues and we are all over 30k miles on our original pumps. We all unlock our cars from relatively long distances and walk to the car thus providing ample time for the pump to prime before we start the engine. Just a wild shot in the dark... Last edited by smallseafishie; 05-05-2010 at 10:09 PM.. |
05-05-2010, 10:06 PM | #2 |
Rep 77
Like your theory...
I like your theory...I am going to try it...makes sense and it cannot do any harm
Do you think driving style (hard vs "normal") has any effect. Hard meaning always pushing car, reving High..etc... Do you think driving conditions have anything to do with it too...ie long distance vs short drives... Or maybe it is just the luck of the draw |
05-05-2010, 10:33 PM | #3 | |
110
Rep 2,017
05-05-2010, 10:37 PM | #4 |
483
Rep 10,309
Drives: A///MERICAN!!!
While I haven't owned my car long enough to tell, it's still on it's original pump 37k miles and I don't go over 4k rpm until it's fully warmed up...I can hear the pump turning on when I unlock it and usually wait for the whirring noise to go away before I start the engine...assuming the engine/pump is "primed" by then
05-05-2010, 10:43 PM | #5 |
Rep 151
you know...i noticed today that when I rushed into the vehicle and started it...it took a TINY bit longer to crank than usual...not sure if it is a cause of the problem but it doesn't hurt to take a minute longer before actually starting the car
I think babying the car for long periods of time will hurt it though as well...the car is meant to be driven so do not be afraid to take the car the length of the powerband often...this does not necessarily mean stomp on the gas...just work the RPMs...give your car a nice lil' workout |
05-05-2010, 10:46 PM | #6 |
483
Rep 10,309
Lol I'm not scared to give her a workout...just not before the temp gauge reads 210*
05-05-2010, 11:17 PM | #7 |
22
Rep 1,938
This is an interesting thread. I would only add that companies that invest more in engineering than joy are expected to make sure that it does not matter how the car starting procedure is implemented, and it should not matter how hard the car is run, within reasonable limits.
05-05-2010, 11:37 PM | #8 |
Rep 151
I was referring more to smallseafishie...didn't see your post BTM before I replied buddy ...and I agree with you...gotta wait for the engine to warm up before having a little fun
Just putting it out there cause peak hp occurs around 5600 if I'm correct...and smallseafishie was saying he gets to 4500 every once in a while...that's at least 1500 more RPMs of joy!! |
05-05-2010, 11:50 PM | #9 |
361
Rep 5,873
Drives: m
10k miles here and no pump issues. I do wait for a few seconds to start the car and never let the tank get below 1/4. I believe thats what keeps me pump problem free.
05-06-2010, 12:02 AM | #10 |
110
Rep 2,017
05-06-2010, 12:03 AM | #11 | |
110
Rep 2,017
05-06-2010, 12:07 AM | #12 |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
Regardless if your theory is correct or not that is REDICLOUS that you have to unlock your car for a few seconds before your car function properly LOL.
However, playing devils advocate, I always unlock my door from distances, Put key into slot nice and slow. Blah blah Still had HPFP. Ive also tried doing the whole process fast and had long cranks. I dont think your theory holds any water, it simply the luck of the draw and/or too many factors contributing to the whole perhaps, making it difficult to pin point. Possibly a combination of Fuel, driving habits, tune, luck, unlock door, weather etc |
05-06-2010, 12:20 AM | #14 |
110
Rep 2,017
05-06-2010, 12:26 AM | #15 |
361
Rep 5,873
Drives: m
The last time i was on here a few months ago, there was talk of a new fuel pump that was suppose to be the answer. Did that work?
05-06-2010, 08:34 AM | #17 |
483
Rep 10,309
FWIW most times starting my car it is already unlocked. I don't lock it in my garage, and considering it's literally parked right outside my office and I can see it through the window I usually don't lock it here either. My startup procedure is put the key in, plug my phone in and get whatever else situated (water bottle, what have you) and then start the car, so there is probably about 30sec. Not sure if this makes a difference, but it's what I do when starting any vehicle not just because I'm scared of pump failure
X2 on not going below 1/4 tank... |
05-06-2010, 08:53 AM | #18 |
163
Rep 2,979
Drives: 07 SBM E92 335i 6MT
I wonder if anyone at BMW is sitting around thining about any of this stuff? I would say probably not. This is rediculous that we have to worry about all this....but I guess I will from now on. I had the engine malfunction reduced power 4 times. I took it in and it ended up being the pressure sensor. I'm still wondering if this is a symptom before it actually fails. I'm at 32K and I'm starting to think that posting anything about this on here is just going to jinx me at this point, lol...
In the process of restoring an 07 335i
05-06-2010, 09:52 AM | #19 | |
110
Rep 2,017
On a second thought, I think my car locks itself if it's been unlocked after a long while? I can't remember... |
05-06-2010, 10:01 AM | #20 |
398
Rep 4,084
thats so crazy it just might work. i remember the only long crank iv ever gotten was right after i immediately jumped in. holy crap. this may be a breakthrough.
7/18/09- I pick up my baby- 2009 E92 335i Xdrive, Space Gray over Coral Red. Premium Pkg, Cold Weather Pkg, M-Sport Pkg, 193Ms, Gloss Black grills, Custom Gloss Black Mirrors, Performance shift and E-brake boot, M3 spoiler, Euro fog switch, gloss black interior tim, Coco-Mats (red/black), H&R coilovers, 19'' Alufelgen SF-71s......
05-06-2010, 10:22 AM | #21 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
It also makes sense to see fuel pumps fail for people who drive their cars primarily in the city. Such people start/stoop their engines more frequently and accumulate less miles. Each time the engine is started AND the fuel system is not pre-primed properly will put strain on the HPFP. This means that city rats like myself will experience HPFP failures more frequently. Mine went belly up at 7,500 miles.
On the other hand people who drive primarily on the highway, I suspect, that they may not have HPFP problems till much later. Just another theory... The fact is, priming the fuel system is VERY important and especially for DI engines like ours. |
05-06-2010, 12:33 PM | #22 |
Rep 175
This has been mentioned before but... I just got a software update to deal with pop up turn arrow not working and loss of ipod control when restarting car. I have comfort access and now when I touch the handle to unlock I hear a new whirring noise, most likely fuel pump priming. This was not the case before the update. I have seen some posts that report dealers are trying a software upgrade before pump replacement.
wow, it's not dirty.
