05-05-2010, 05:48 PM | #1 |
I love my Z. Pure sex on wheels.
48
Rep 397
How to: remove plastic trunk tray, and still have a open & closing top.
Hey guys, I dont know about the majority on here, but I've always had problems with that almost useless plastic tray coming off its hinges and thus not triggering the switch: allowing the top to go down or up.
The tray is one thing, but having it positioned so that it properly activates the switch is another, so I opted to remove it: since for my subwoofer install, it just rattled itself loose constantly, and was quite poorly designed in the first place. So step 1) Remove the tray, as it'll pop off its hinges, from there just angle it out of the trunk of the car and set it aside in some far corner of your garage: as you'll never need to use it again. Step 2) Use a medium torx bit to remove the switch assembly (two screws, about 3/4" in total length), of which the knob on the tray will hit against. http://www.flickr.com/photos/49522574@N06/4582669686/ Here, this is it fully removed. Its a bit of a PITA having to force your body into these orgami like contortions to fit into the trunk, and properly dis-connect it, but after you do that, this will be the back side that needs to be modified (dont get worried its painfully easy) http://www.flickr.com/photos/49522574@N06/4582669688/ Use a trouble light/flashlight to see what you're doing inside the trunk, seriously! Remember not to force the connector apart or it'll never properly re-attach as its locking mechanism will be broken. Step 3) Basically you want to bypass the switch. Using a multimeter I found that when the switch is in the (physical) closed position, the circuit is closed. When ever the electrical system is not in a closed loop (as in: the switch has not been tripped/closed) that tells the car to not attempt to operate the power top in anyway. So: bypass the switch by closing the circuit yourself/soldering the two wires together. http://www.flickr.com/photos/4952257...n/photostream/ Obviously, COVER IT IN ELECTRICAL TAPE AFTER! You dont have to solder it per se', but I have a soldering gun and I can do it, so I did. Alternatively you can use the "Marrett" twist connectors, but make SURE they're on there tight, and electrical taped on there. Since I dont know about you, but I dont want these wires separating and thus you can't close the top when it starts raining. Now, you can re-install the old switch cover if you want, or just leave it be. Either way, you're done. ! any questions, just ask here or PM me, and I'd be happy to help
05-08-2010, 06:07 PM | #3 |
48
Rep 397
^ Yeah thats true. I noticed that after finally doing this myself. It doesn't bother me, even with a stereo in the back of it, but if it were to really bother other people: just put a light tint on the rear window and that'll cure the problem.
05-08-2010, 06:47 PM | #4 |
190
Rep 2,431
thanks,
Ironic b/c last week while installing my coilovers I busted my microswitch and I ended up doing the same thing
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
01-17-2012, 04:41 PM | #7 |
48
Rep 397
Bump, holy shit I forgot I even made this thread until I checked this car audio DIY guide a made a LONG time ago as well. I forgot I even had a Flickr account too. hahaha
Talk about a trip down memory lane.
