DIY: LED licence plate lights (Version 2)
12-01-2006, 01:02 AM | #1 |
81
Rep 1,391
Drives: F10 G29
Hi,
I have just changed my LED licence lights to a more simple set up For your information, please refer to the link below for what I did few months ago http://www.e90post.com/forums/showth...&highlight=LED For the old LED I was using, I found it is kind of blue and the brightness is not good enough. So, I switched to these LED lights. |
12-01-2006, 01:05 AM | #2 |
81
Rep 1,391
Drives: F10 G29
From another model of this brand, I found these adaptor which is fitted with a 270Ohm resister inside.
12-01-2006, 01:09 AM | #3 |
81
Rep 1,391
Drives: F10 G29
However, these adaptor (w/ 270 Ohm resister) is NOT designed to be used with the 6 LED.
Since our E90 licence plate light is connected in parallel, using one adaptor at each light will use you around 135 Ohm. This will still trigger the error message. We only need to drop the resistance a little bit to make it work. I added a metal foil resister in the left housing. Last edited by rikuF10; 12-01-2006 at 02:12 AM.. |
12-01-2006, 01:11 AM | #4 |
81
Rep 1,391
Drives: F10 G29
here is the right housing....by the way, I have cut the black square plastic piece off since it is blocking half of the lights
12-01-2006, 01:14 AM | #5 |
81
Rep 1,391
Drives: F10 G29
Here is the result...
the lights are more white and brighter. A more simple setup with no more wires. Last edited by rikuF10; 12-01-2006 at 02:10 AM.. |
12-01-2006, 05:24 AM | #6 |
pull my finger to get your kinder® surprise
148
Rep 10,455
good job, dare I say, it now looks more like the license plate lights on the newer Lexus (or is that Lexi for plural?)
12-01-2006, 06:21 AM | #7 | |
81
Rep 1,391
Drives: F10 G29
Just compared with a drive-by GS300, the color is the same. The only difference is the brightness, mine is actually much brighter than the GS300. Maybe I shouldn't cut off that plastic piece in the housing. Anyway....will try it with another set of housing next week. |
12-01-2006, 07:28 AM | #8 |
148
Rep 10,455
would you mind taking pictures of it in the dark? (the last pic is in an underground parking garage I assume?)
12-01-2006, 06:13 PM | #9 |
31
Rep 799
Any links on where to purchase these LEDs? Or even better, a 3 LED version of it? I couldnt find them on google or ebay
Edit: I guess I didnt look hard enough: 6LED version at http://cgi.ebay.com/JAPAN-LUXER1-6-L...QQcmdZViewItem Last edited by rrandyy; 12-03-2006 at 02:00 AM.. |
12-01-2006, 07:07 PM | #10 |
37
Rep 621
My license plate interior mod + interior LED mod.
Thanks for the great DIY post RikuE90 (i follow your old post) I got my LED bulbs from http://www.superbrightleds.com/ and heat sink resistor from http://marvac.com/ |
12-01-2006, 07:55 PM | #11 | |
81
Rep 1,391
Drives: F10 G29
Hi Analog....your LED interior is very nice. May I know how many LEDs are you using in the dome light? |
12-01-2006, 08:12 PM | #12 | |
37
Rep 621
Hi:
I use the 921 x12 bulb. It's just a wedge bulb with 12 LED. you can find it on the link i posted above Quote:
12-01-2006, 08:29 PM | #13 | |
81
Rep 1,391
Drives: F10 G29
Do you find the 12 LED bright enough for the interior in person? My friends tried using the Luxer1-brand 12 LED, but it is not bright enough. They are now using the 24LED version of the same brand, and it can light up the whole cabin. |
12-01-2006, 09:44 PM | #14 |
87
Rep 1,032
Drives: 2006 330i & 2010 535i
Analog.....that's a sweet set-up
2006 330i Jet Black w/ Beige Leather/Sport/Prem/Step/Shades/Xenon/Logic 7 |
12-01-2006, 10:59 PM | #15 | |
37
Rep 621
I think the 12 LED is not as bright as the halogen bulb. But i think it is good enough for me. I was trying to buy the Luxer in the states, but I had no luck finding it. |
12-01-2006, 11:17 PM | #16 | |
17
Rep 54
12-02-2006, 10:03 AM | #17 | |
81
Rep 1,391
Drives: F10 G29
The two small resister inside the adaptor will get hot. However, it is still not as hot as a halogen bulb. The piggyback one is not even warm since it has a much lower resistance. In my previous approach, the 37mm 6-LED bulb was the only thing I can find at that time. Adding three resisters needs more space, so I used heat shink resister because I will be hiding it inside the trunk. Now with this new LED adaptors, there are already 2 resisters built-in. So, no need to worry about the heat, because you won't touch it as you won't touch the stock halogen bulb. Adding a third one is much easier. |
02-02-2007, 07:36 AM | #18 |
Rep 15
around how much will it cost to just replace the license plate lights?
and whats the difference between the 2 setups..the one from superbrightleds and the luxor1? just the brightness..?cuz the luxor one setup is about 3 times more expensive than the suprebrightleds one..sorry for the dumb question but im not sure i got the idea right |
02-02-2007, 12:08 PM | #19 |
81
Rep 1,391
Drives: F10 G29
The luxer1 LED is much more expensive (US$20 vs US$6 each), and they brighter too. It looks more like the Lexus GS's licence light than the Superbright LED which I used before.
02-04-2007, 11:01 PM | #20 |
3274
Rep 6,723
Riku
I saw the 6 LED unit on their web site but where did you get the adapter from? What product line? It looks like the package you have in the first post comes with it included... is that the one I need to buy (entire package) so it comes with the adapter? Thanks |
02-05-2007, 03:58 PM | #21 |
Moderator
497
Rep 27,441
thanks for the write up!
so are you saying the resistor (inside the festoon bulb) that comes with the kit is not good enough? and that using what comes with the kit alone will still result in bulb out error?
02-05-2007, 05:21 PM | #22 | |
31
Rep 746
Drives: 2007 328 Coupe Alpine White
Just did this mod. After 10 minutes switched back to regular license bulbs for now. I have more LED's on order. The first ones I used were just like yours. WAY too blue. They seemed bright enough, but so blue it puts me at risk of getting pulled over!! I have two more sets coming, in different styles, so I'll see which one I like best. One is a 9 LED bulb (vs. 6), the other is a 1 watt high power. I'll keep you posted. |
