2000 328i oil change
05-01-2010, 01:51 PM | #1 |
Rep 4
I have been searching for around 30 min and I keep finding threads with differnt years and engines so for my specific engine I thought I would ask where is the oil filter for my car. I am used to american cars where it is easy to find on the bottom of the oil pan on LS series of engines. I was going to put some castol GTX high mileage SAE 5w-30 in it just wondering if this wouldnt work for any reason. Thanks for the info.
-00 Silver 328i.
05-01-2010, 02:53 PM | #2 |
Rep 4
-00 Silver 328i.
05-02-2010, 03:15 PM | #3 |
23
Rep 257
Your 2000 328i requires bmw synthetic oil. The oil filter is located on the top of the engine and you will need a 36mm socket to remove it. The oil pan and drain plug are located underneeth the car ( like any car) but bmw's have plastic protective coverings. To access the oil drain plug you will need to remove the acces covering that is shaped similar to a triangle the bolt is
17mm. |
