Need some help guys on Wheel Size?
04-16-2010, 11:09 AM | #1 |
AKA: MyKaL
21
Rep 202
I am debating between getting 20" wheels or 19" wheels for my E92 335i. The 20" will be 20x9 front on 245/30 and 20x10 back on 285/25 Falken tires. The 19" will be 19x9 front on 245/35 and 19x10 on 275/30 Falken tires. I will also have KW V2 coilovers and my delemma is that I don't want to rub, but I want to be as flush as possible with very little wheel gap. I know ride quality will suffer a bit on 20" but they look sick. I did do some searching on here and there is not much info on 20" wheels. Should I just go the safe route and go with the 19"? Thanks for your help. I don't know much about wheels and tires fitment on these cars.
Still not faster then a crown vic!!! |
04-16-2010, 11:17 AM | #2 |
475
Rep 13,583
Drives: JB E92 335i
Check out the Forgestar F14 flow-form wheel available in 18, 19, 20 with custom wheel sizing and offsets to accommodate your needs!
Available Offsets and Sizes 19x8.5 offsets from +26 to +48 19x9.0 offsets from +20 to +50 19x10 offsets from +20 to +45 19x11 offsets from +23 to +55 20×8.5 offsets from +26 to +50 20×9.0 offsets from +18 to +56 20×9.5 offsets from +7 to +43 20×10 offsets from +31 to +69 20×10.5 offsets from +20 to +55 20×11 offsets from +48 to +81 20×12 offsets from +39 to +75 You can check out an extensive gallery here: [IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/Gallery/Forgestargallery.jpg[/IMG] |
04-16-2010, 12:41 PM | #3 |
AKA: MyKaL
21
Rep 202
Thanks for your reply but I already have my wheels picked out. I just am wondering if I will have issues with 20" wheels?
04-27-2010, 02:52 PM | #4 |
AKA: MyKaL
21
Rep 202
Bump for a reply? I need help to figure out if I should get 20 inch wheels or 19inch. The size of the wheels cost the same, it is just a 300 dollar difference in tires. Not sure on ride quality and rubbing? I don't see many people on this forum with 20's but I heard this is going to be the trend. Please chime in. Thanks in advance for your thoughts. Need to make a decision soon.
04-27-2010, 03:28 PM | #5 |
18
Rep 377
I'll chime in. The only problem with your question, it's hard to respond on rubbing with no offset information on the wheels you are running.
I ran 20x8.5/ 20x10 30mm all the way around on an E90. I had about an 1.5" drop and I had to do a slight fender roll. The only time I expercienced any rubbing was on hard compression when turning into a driveway. The only difference though on your E92 an ET30mm 20x10 is too aggressive if you are concerned with rubbing. I don't think you can go wrong on either size just do what you want. |
