Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > DIY: Removing and installing filter housing and throttle body / Dinan Part Deux
      11-23-2006, 12:14 PM   #1
ksfrogman
ksfrogman's Avatar
576
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
During this DIY, I am replacing my existing Dinan Throttle Valve Body with another one. Although this baseline install starts with an existing GruppeM intake, I will include BMW's photos of the OEM filter housing as well.
The instructions to change out the OEM throttle valve body assembly are the same.
Time required: Approx. 40 minutes.
Tools needed:
Stubby slotted screwdriver
Small slotted screwdriver
Larger slotted screwdriver
Torx screwdriver (not shown) - for OEM filter housing
Phillips screwdriver - for GruppeM intake
10mm socket and 3/8-inch drive ratchet
Dinan throttle body is in the ziplock bag
Removing OEM filter housing:
Unlock plug (1) and remove. Release clamp and detach air intake hose (2).
Unlock air intake hose (1) sideways and detach. Release bolts. Remove intake filter housing (2) towards top.
Removing Gruppe M Intake:
Locate the phillips screwhead bolt near the driver's side strut tower and remove it.
Unplug and remove the connector to the air mass flow sensor.
Disconnect (retract) the air inlet hose from the CF housing.
This is what the GruppeM intake looks like removed from the car.
The engine compartment with the intake removed.
Loosen this clamp using a slotted screwdriver.
Air intake tube with silencer.
Back to the engine compartment, look at the remaining intake tube elbow that attaches to the throttle body. Remove the tiny air hose shown in the following diagram (red arrow). Pull this hose in the direction of the yellow arrow.
Loosen clamp that attaches the intake pipe elbow to the throttle valve body.
Remove the elbow.
Now you can see the throttle valve body.
Remove this connector. This is what conveys the electric signal to open the throttle valve.
Remove the 4 bolts shown here from the throttle body assembly (2). The plug that you should remove is shown in (1). Remove throttle assembly.
When reinstalling the throttle assembly (2), make sure to replace the sealing ring (1). The Dinan unit comes with a new sealing ring.
To reinstall, do the above in reverse.
      11-23-2006, 12:35 PM   #2
arcrox
E90post addict
arcrox's Avatar
17
Drives: 2024 G20 M340i
2006 325i  [0.00]
Have you dynoed it yet?
      11-23-2006, 12:41 PM   #3
ksfrogman
ksfrogman's Avatar
576
2006 330i  [0.00]
2006 330i  [0.00]
Some caveats
- It helps to have good lighting. I use a retractable fluorescent shop light.
- You must remove the plastic elbow from the throttle assembly in order to access the bolt on the upper right hand corner. It follows that when you are reinstalling, you must attach the throttle assembly to the air inlet of the intake manifold before you put this elbow on.
- The plastic elbow is a critical part that must snap into place! Since you are working somewhat blindly when attaching this piece back, you may want to practice attaching the plastic elbow to the throttle body and removing it before the actual reinstall.
- Don't forget to reconnect the air hose and electrical plugs. Without them, your throttle valve will remain closed, or your MAF will not function.
The $500+ question
If you take a close look at the last photo above, the inlet diameter of this collector (as it turns) for intake air seemed more narrow than the diameter of the throttle valve assembly bore.
One would intuitively question whether the throttle body bore is the most restrictive component for the flow of intake air.
See brightened photo attachment below.
I did this on Thanksgiving morning. Turkey, gravy, mashed potatoes, wild rice, cranberries, corned bread and pumpkin pie, and days of leftovers before re-dyno next week.
      11-23-2006, 01:36 PM   #4
txusa03
550
Drives: TS330iPPSP6MT
I dont get it? I read all your comments but it seems like you replaced one dinan for anther dinan. why? what is the diff between the one already in the car vs the one in the ziplock bag? I am not a mechanic so I do not understand. How much for the part as well?
under construction!
      11-23-2006, 01:43 PM   #5
just4kickz
boku no namae ha...
336
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
2006 E90 330i  [0.00]
nice write up... alotta work tho haha
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!"
      11-23-2006, 02:01 PM   #6
ksfrogman
ksfrogman's Avatar
576
2006 330i  [0.00]
2006 330i  [0.00]
The 1st Dinan unit produced lower than expected dyno results. Click on the dyno link in my sig. Intuitively, this did not make sense unless the modded throttle valve was not opening correctly. Other variables secondary to DME inputs from the multitude of sensors (e.g., radiator outlet temperature sensor, charge air temperature sensor, coolant temperature sensor, evaporator temperature sensor, fuel temperature sensor, exhaust backpressure sensor, intake pipe pressure sensor, engine collant temperature sensor, blah blah blah) may be at play. I refer you to the previous thread and links to Steve Dinan's white paper regarding Dynamometer Testing and the Modern BMW Engine.
This seems to be the logical next step.
      11-23-2006, 05:53 PM   #7
mosport70
mosport70's Avatar
Drives: 330xi
2006 330xi  [0.00]
2006 330xi  [0.00]
2006 330xi  [0.00]
Outstanding write-up. Quality post as usual frogman.
Surely this will find its way to the DYI file!
330xi Sparkling Graphite | Terra with Burl Walnut | ZPP | ZSP with Style 162 | Comfort Access | Heated Seats | PDC | Navigation | Satellite Radio | OEM Alarm | De-badged | OEM Strut Brace | Blacklines | Rear Fogs | Silver Front Indicator Bulbs
Ordered: 4.3.2006
Scheduled for Production: 4.7.2006
Awaiting Transport: 4.13.2006
En Route: 4.19.2006
At Preparation Center: 5.11.2006
Performance Center Delivery: 06.01.2006
      11-24-2006, 11:26 AM   #8
RodyP
RodyP's Avatar
Netherlands
61
Drives: 19 Bmw M5 Competition
can we delete the silencer in the air intake pipe and does it have an big effect
      11-24-2006, 11:34 AM   #9
ksfrogman
ksfrogman's Avatar
576
2006 330i  [0.00]
2006 330i  [0.00]
That would be a nice project for you. Buy a spare intake pipe and plug up the hole. I'd be careful not to use anything that would dislodge and ruin your engine. It would have to form an airtight seal, be durable, withstand some heat, and adhere to the plastic composite material.
Do it and let us know how it sounds.
      11-24-2006, 11:47 AM   #10
RodyP
RodyP's Avatar
Netherlands
61
i will do it next week, can't wait for the results, how does the trottle body preforms ? i'm considering it
      11-24-2006, 01:27 PM   #11
ksfrogman
ksfrogman's Avatar
576
2006 330i  [0.00]
2006 330i  [0.00]
I can't tell at all. The open differential mod made a huge difference, but the throttle body swap seemed so inert that only a dyno might reveal a change.
One more idea you might consider. You could use a metal flat washer and long bolt. This would plug up the hole, and you wouldn't have to worry about pieces dislodging into your intake. You might use high temp silicone to seal off the other end of the bolt to which you would fasten a locking nut or nut/lock washer.
Here's an "x-ray" drawing:
      11-24-2006, 01:36 PM   #12
RodyP
RodyP's Avatar
Netherlands
61
thanks for these ideas.. i will make a d.i.y when i'm done i'm thuesday at my local body shop so i will try, where dit you get the open diff ?
      11-26-2006, 11:46 AM   #13
Jason
Administrator
Jason's Avatar
40865
Drives: F80 M3
Great write-up Michael, thanks for sharing. Added to DIY master list - http://www.e90post.com/forums/showthread.php?t=1721
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      11-26-2006, 08:10 PM   #14
///Matt
United States Marine
///Matt's Avatar
318
Drives: 2007 Dodge Ram 1500
2006 330i  [0.00]
This would cause a turbulence in the intake flow... no good. If you found a way to make the portion of the bolt/washer that protrudes into the intake boot flat, then cool.
Also, speaking of turbulence, that's the secondary job of the silencer. It lowers noise AND acts as a buffer for intake pulses.
      11-26-2006, 08:23 PM   #15
ksfrogman
ksfrogman's Avatar
576
2006 330i  [0.00]
2006 330i  [0.00]
Good info. If you look at the inside of the pipe, it's anything but completely smooth, particularly with the ridges from the telescoping plastic. The portion that the bolt head would rest would be contained within the recessed area, not protruding into the air channel. Of course, a flat, and round bolt head would be better than a hexagonal one that protrudes.
      11-26-2006, 08:25 PM   #16
///Matt
///Matt's Avatar
318
2006 330i  [0.00]
I agree that the inside of the boot is not exactly flawless, but keep in mind that it's tuned, and engineered, to run the way it does. =)
      11-26-2006, 08:29 PM   #17
ksfrogman
ksfrogman's Avatar
576
2006 330i  [0.00]
2006 330i  [0.00]
Another interesting observation is that the Fujita intake, which several believe actually decreased power, replaces this entire piece with a metal tube. The Fujita adapter that goes into this pipe to the throttle assembly is very cheap looking with the same inner diameter on either side of the adapter, despite the different outer diameter male ends that attach to the adapter. The additional variable is that the Fujita has its own opening for the MAF sensor.
      12-06-2006, 12:21 PM   #18
uhaulball
195
Drives: e90 330xi
so are u saying the fujita performed poorly because of the lack of a silencer?
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005
      04-14-2012, 12:24 AM   #19
raybenz2011
QUICK LITTLE BLACK BAVARIAN BEAST
raybenz2011's Avatar
Drives: BMW 328i BAVARIAN AUTO
blah blah blah i like it!
One quick Question Sir Ks frog man! Did it Help and Where are the pics????? or could it have been cleaned?? and you missed a sensor like the infamous mass air flow sensor blah
      02-06-2013, 10:52 AM   #20
jokers_greg
Master of Montego Blue
jokers_greg's Avatar
28
Drives: 2007 BMW 335i
2007 335i  [0.00]
+1 for this thread revival
      03-06-2013, 10:30 AM   #21
willfx
Drives: e90 320d
When I replaced the Throttle Body for my e90 320d it made a huge difference.
Didn't knew, but my old one it was broken I think since now the car works smoother.
      05-30-2017, 03:46 PM   #22
SID2GO
Drives: Bmw e90 325i N53
Tools needed:
Remove the elbow.
could you repost the images please
