What size spacers for 8.5" wheels on E92 335i?
04-13-2010, 05:20 PM | #1 |
17
Rep 194
So I've decided to convert my stock 189's to winter duty and purchase a set of Miro 942 18x8.5" rims. I figured the square setup will allow me to rotate the tires once I burn through the staggered set I will be putting on now (moving over from the 189s). I've also read that I can get a staggered look on a square setup by running spacers in the back. What size spacers would you guys suggest I run with 8.5" rims in the back (35 offset) on an E92 335i?
04-13-2010, 06:13 PM | #2 |
375
Rep 17,017
Good choice on the wheels, very clean design. For the rear wheels, I suggest a 15mm spacer to make it flush. You can also wait to mount the wheel and tire and measure the distance between the tire and fender.
04-13-2010, 06:27 PM | #3 |
64
Rep 878
An 8.5" width wheel with ET 20 is approximately equivalent to a 9.5" width with ET 33, so I'd say you could probably even go with a 20mm spacer if you'd like.
04-13-2010, 07:02 PM | #4 |
17
Rep 194
I'm not that familiar with how the offsets are measured so how does that work? I thought an offset of 33 would push the wheel out 2mm (vs 35) and having a 9.5" vs an 8.5" wheel would push it out another 13mm so wouldn't that make your 2nd case 15mm further out than the 8.5" I'm looking at?
04-13-2010, 07:03 PM | #5 |
17
Rep 194
Thanks for the suggestion, I'll probably wait and measure it. I was never really bothered with the stock 8.5" rims (don't know the offset on the 189s) so maybe I won't even need spacers?
04-13-2010, 07:06 PM | #6 | |
64
Rep 878
Sorry for the confusion. Last edited by deanmc; 04-13-2010 at 07:11 PM.. |
04-13-2010, 07:06 PM | #7 |
257
Rep 4,048
We've got a great Spacer DIY right here, feel free to check it out:
▀▄ eas | Macht Schnell Competition Wheel Spacers DIY Instructions http://www.e90post.com/forums/showthread.php?t=332063 That should help out! |
