Tyre pressure (European values) for non-RFT PLEASE HELP!
04-06-2010, 03:16 AM | #1 |
653
Rep 2,705
Hi guys,
Just installed non-RFT Michelin PS2 tyres (19" 255/30/19 (rear) & 225/35/19 (front). The current pressure setup (with GAS) is 2.8 rear and 2.5 front. The ride feels softer and a bit wobbly. My question is what would be the ideal pressure for my car. Please help, I asked the guys at the shop who had them fitted, but I do not think they are such experts when it comes to non-RFTs on a E92. Thanks a lot! |
04-06-2010, 03:58 AM | #2 |
56
Rep 1,311
The ride SHOULD be softer with non-RFT. If you feel wobble it is probably a tyre issue (e.g. poor balancing). I'm using 2.5 rear and 2.3 front on 255/35/18 and 235/40/18. The car runs fine. These pressures provide good grip and comfort. The razor-sharp turn-in with RFT's is of course lost with non-RFT, but the total outcome is a big win. The car is less nervous and more comfy with ordinary tyres. I'm using Hankook V12's.
04-06-2010, 04:15 AM | #3 | |
653
Rep 2,705
04-06-2010, 04:37 AM | #4 |
56
Rep 1,311
I use ordinary air :-) I know aircraft may use some gas (nitrogen perhaps) to avoid tyre expansion when they become very hot, but this is not a real issue for cars.
RFT's have extreme good turn-in behaviour, so it may take some time to get full commitment to non-RFT's. Especially since the chassi is designed for RFT's. It is however just good if the tyres moves a bit, to keep grip on uneven surfaces. I have a M-sport chassi and non-RFT's works real fine with it. Others have changed to M3 suspension when going to ordinary tyres. No problems for me to slide on dry tarmac with good control, the V12’s are great, as your tyres should be. The first impression with the non-RFT's is that they may bounce a bit in potholes, instead of being totally stiff as the RFT's. |
04-06-2010, 09:02 AM | #5 |
31
Rep 309
I have it from a reliable source that 2.6 bar all round is the way to go. That is what I am running and all seems well.
335d Xdrive Msport Plus, ACS springs and lots of toys
Range Rover Evoque Dynamic Lux VW Touran 1.9Tdi, 18" wheels, superchipped and lowered! |
04-06-2010, 09:19 AM | #6 | |
653
Rep 2,705
I did some research and I have found the same (that all tires should be the same, on the pressure I keep finding different values). What you mean is that all 4 tyres should be 2.6? Last edited by 1230vani; 04-06-2010 at 09:24 AM.. |
04-06-2010, 09:22 AM | #7 | |
653
Rep 2,705
04-06-2010, 09:23 AM | #8 |
653
Rep 2,705
04-06-2010, 01:07 PM | #9 |
12
Rep 86
I once got hold of the formula the car- and tire-manufacturers use to determine the advice pressures.
Worked it out first for campers and later for normal cars and learned myself Excell to make spreadsheets for it. Translated a few from Dutch to English to go worldwide with it. http://cid-a526e0eee092e6dc.skydrive...0tyre-pressure In this map the spreadsheet and examples to re-calculate advice pressures when you have other then original tires on the car, and to check the original and see if you can savely go lower in sertain conditions. Collect the data asked on the first opening sheet and fill in . Let me know if you used it and what the outcome was |
04-06-2010, 01:22 PM | #10 | |
56
Rep 1,311
04-07-2010, 09:30 AM | #11 | |
653
Rep 2,705
04-14-2010, 09:00 PM | #12 |
108
Rep 931
I swapped from RFT RE050As to non-RF PS2s recently. At first I experienced the same feeling as you - a slight softness initially, then grip, then more softness as the grip goes. I'd been running 2.6 all round on RFT's (17's, M-sport) so increased to 2.7 F/2.8 R. This really made little difference.
However, after 2000km of driving, they are wonderful - the bite has improved so they are almost as sharp, no longer feel soft and have limits that are much higher in wet and dry conditions.
John
17 F87 M2 Pure - long beach blue 10 E91 320d LCI - space grey - black dakota - steptronic - innovations - 157s - front PDC - Konis 99 BMW Baby Racer - red; 05 Renaultsport Clio 182 Cup - French Racing Blue - Konis - Eibachs - Remus - Turinis |
