My BMW feels wobbly.
04-05-2010, 01:12 PM | #1 |
BMW forever!
1392
Rep 2,420
Hi, how's it going?
Lately I've been noticing that my car wobbles and doesn't feel as solid/stable like it used to be. I've checked the tire pressure and it looks fine too! I did hit a few pot holes the last month or so but none of them were above 30 mph. Just wondering if you guys have had a similar issue before? Some symptoms: -drive is more wobbly than before -steering slightly looser than before -when braking hard, car tends to pull to the right or left -steering sometimes shakes more than normal when going over rough surfaces Tire pressure is normal: 32F/35R and have also played around with different configurations, issue still exists. I couldn't visually tell if I have a bent rim or bubbles in my tire. I have an appointment with by service adviser next week as well. Thanks!
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
04-05-2010, 01:14 PM | #2 |
119
Rep 2,312
I have similar symptoms
-steering loser -my alignment is def out, courtesy of some third rate infrastructure in manhattan and philadelphia. -when braking in wet conditions, my car pulls to L or R |
04-05-2010, 01:50 PM | #3 |
148
Rep 1,728
1. When have you last gotten an alignment?
2. Check to make sure your wheels are properly balanced
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
04-05-2010, 01:55 PM | #4 |
Rep 364
i have the same thing i did alignment tires balanced
and i still get the same thing ...... i iinstalled eibach springs few weeks ago
Black 335I
04-05-2010, 02:13 PM | #5 |
Rep 64
^ If you lowered your car after your alignment its likely you will need another one - depends on the drop.
Things to consider if your car wobbles: - Bent wheels - Bad alignment (car could pull to a side under hard braking) - Warped rotors (wobbling happens on braking) - unbalanced wheel + tire combo |
04-05-2010, 02:29 PM | #6 |
台北 台灣
43
Rep 619
Drives: 2004 MazdaSpeed Miata
I have the same feeling! I do need an alignment and I talked to my SA about that he told me because I have aftermarket wheels(v710) They cant do alignment for me cuz they dont have the equipment.
Guess Ill have to find another place and see if it helps. |
04-05-2010, 02:32 PM | #7 |
Rep 143
Drives: 335i Coupe 6MT SpaceGrau
I have seen some big f-ing pot holes that will mess your car up at 15mph.
Current: 2007 335i coupe SpaceGrau
Retired: 2006 325i, 1994 325i |
04-05-2010, 06:53 PM | #8 |
AC Schnitzel
85
Rep 546
+1 i have the exact same issue..my car feels like its on the suspension of an oldsmobile recently..steering feels less responsive and loose, my shocks are squeaking and i keep on thinking about changing out the suspension/coilovers..let us know if anyone has taken their car to the stealership for any of these issues!
04-05-2010, 11:32 PM | #9 |
10
Rep 69
My car has a similar loose feeling, steering is not as tight as it use to be, the turn in is still sharp but no real feel of the road. Feels like a Lexus now... maybe not that bad, maybe more like a MB.
I've told the dealership during my last service, the SA at my dealership said "You shouldnt complain about that, lighter steering is a good thing" |
04-07-2010, 01:20 AM | #12 |
BMW forever!
1392
Rep 2,420
Thanks everyone, I have made an appt. with my dealership early next week and will keep you posted about the diagnosis!
2020 BMW X5
04-07-2010, 02:27 AM | #13 |
BMW forever!
1392
Rep 2,420
Interesting old thread, thought I'd share it here -
http://www.e90post.com/forums/showthread.php?t=2613 It could be the tire pressure that we probably need to play around to get that taught steering feel back...
2020 BMW X5
04-07-2010, 03:50 PM | #14 |
BMW forever!
1392
Rep 2,420
The magic tire pressure numbers are:
Front 30 PSI Rear 33 PSI The car handles like a dream. I think the recommended tire pressure is inaccurate or maybe it only applies to Euro roads/weather conditions. That link I posted above definitely helped!
2020 BMW X5
04-07-2010, 04:35 PM | #15 |
22
Rep 339
Thanks for posting - I'm keeping track of this thread as I'm beginning to think I have this issue (albeit on a less significant level) as well
For those tire pressures, is your car a coupe or sedan?
2007 328i coupe - Sport, Premium
2010 Ducati Monster 696 |
04-07-2010, 05:33 PM | #16 |
BMW forever!
1392
Rep 2,420
Mine is a 2009 328i Sedan. Also check out the link I posted above and make sure to measure your tire pressure first thing in the morning to get accurate readings.
2020 BMW X5
04-07-2010, 05:40 PM | #17 |
43
Rep 434
Drives: 2020 Tesla Model 3
hmmm glad i saw this, I just got my snow tires off (on their own aftermarket rims) and put my stock summer 162's on and noticed the same sensations, I'm thinking its to do with going from a non RFT to a RFT that i'm experiencing this, but I will def. check out the pressure, as the place I go to normally check & fill up the wheels they may have gone a little overboard
04-07-2010, 07:37 PM | #18 |
253
Rep 7,089
Drives: '06 AW 330xi
I got the loose steering and Wobbly feeling after having an accident fixed. Control arm, wheel bearing and spindel were replaced and a toe link mount was reinforced. I hear there's a service bulletin out for certain steering racks. I'm going to ask my dealer about It once im done with school. I think the wobbling, for me at least, Is becuase one of the shocks were damaged and on is leaking now. I'm getting shocks and springs in a month or 2 though.
