Rotating window switches DIY?
02-28-2010, 07:48 AM | #1 |
Rep 131
I almost always roll down the back windows when trying to roll down the front on my E90. Drives me nuts. Is there a DIY out there anywhere that makes the closest switches control the front windows and the further the back? I think that would solve it for me.
LJS330i |
02-28-2010, 08:02 AM | #2 |
90
Rep 2,707
Pop the switch out and see if you can swap out the wiring... it can't be that complicated... but then again BMW tends to over-engineer things, I can just imagine when you press the button and encrypted signal is fired from the switch to the main computer
zhpregistry.net - ZHP stats and free classifieds.
02-28-2010, 08:15 AM | #3 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
you might be able to do it w/out taking the door panel off.
02-28-2010, 10:51 AM | #4 |
167
Rep 7,433
i'd imagine it would be as easy as popping the switches and splicing the wires. but knowing bmw it'd probably throw a code lol
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
02-28-2010, 11:31 AM | #6 |
253
Rep 7,089
Drives: '06 AW 330xi
This bothers me too but no so much as to switch the wires around. I have taken the door panel off and unplugged the cluster of window switches. It is one harness that comes off by flipping a lever....like many other harnesses in the car. You would then need to find which wires control the rear windows and swap them with the fronts. This is very possible. I would take the door panel off though. It's allot easier to remove the cluster from the inside than from the exterior. Plus damage is more likely to occur when prying than pushing.
02-28-2010, 11:34 AM | #7 |
253
Rep 7,089
Btw I doubt a code will be thrown...our switches, in the e90 at least, are common to some other models such as the x5. I had to order a new switch for my passenger side door because I broke the lever to open and close the window. I have had the the switch unplugged for the past 2 months and no errors.
