Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 18" wheels..but rear won't stick out!
      10-30-2006, 12:15 PM   #1
achal
achal's Avatar
53
Drives: X5 E70 Prem, Tech, Cold packg
I got 18" 8'&9' wheels for my car..they look very aggressive cause I had stupid 16" before but I want to have my rear wheel stick out a little more close to the fender or almost inline with fender..U think spacer is the answer to my question..if yes! then how many mm spacers do i need and is it OK to put spacers on without compromising any safety or warrenty issues....
Thanks guys....
      10-30-2006, 12:28 PM   #2
///Matt
United States Marine
///Matt's Avatar
318
Drives: 2007 Dodge Ram 1500
2006 330i  [0.00]
your BEST bet would have been to get wheels with a more aggressive offset. Since you didn't getting spacers is your only option. I won't recommend getting more than 12mm, for safety/warranty reasons, but some people here run 15mm.
Stick with 12mm, with extended lug bolts, and you'll be fine.
      10-30-2006, 12:29 PM   #3
achal
achal's Avatar
53
Thanx matt..did u got my pm..about the xenons I send it on friday....also will spacers void any warrenty.....
      10-30-2006, 12:34 PM   #4
achal
achal's Avatar
53
I am running
18X8.0 ET38
18x9.0 ET42
U think...12mm will do the trick....
      10-30-2006, 12:48 PM   #5
///Matt
///Matt's Avatar
318
2006 330i  [0.00]
12 will look great. I got your pm, didn't you get my response?
      10-30-2006, 01:03 PM   #6
KL2DC
Moderator
KL2DC's Avatar
318
Drives: F36 428i,E90 328i, E85 Z4 3.0i
2015 F36 428i  [0.00]
2011 E90 328i  [0.00]
2006 E85 Z4 3.0i  [0.00]
achal, yep 12mm spacers should do the trick. Get quality ones like Rogue Engineering ones that come with appropriate lug bolts.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call!
      10-30-2006, 01:07 PM   #7
achal
achal's Avatar
53
what is a good site to order these.....??
      10-30-2006, 01:07 PM   #8
achal
achal's Avatar
53
I did not got u r response.....??
      10-30-2006, 01:19 PM   #9
KL2DC
Moderator
KL2DC's Avatar
318
Straight from the source...
http://www.rogueengineering.com/Merc...tegory_Code=WH
btw Bavarian19 has the 12mm setup, I have the 15mm and FrankoQ is planning on adding 15mm.
      10-30-2006, 01:22 PM   #10
achal
achal's Avatar
53
cool....I thnk I am gonna get 12mm..I am getting it installed..they r charging $50 for the installation....Is it easy.....U thnk...I have changed the wheels for my car when I got them.....but don't know whats involved with spacers....
      10-30-2006, 01:22 PM   #11
///Matt
///Matt's Avatar
318
2006 330i  [0.00]
do it your self. All you do is take the wheel off, put the spacer on the hub, and reinstall the wheel with the longer bolts.
      10-30-2006, 01:23 PM   #12
KL2DC
Moderator
KL2DC's Avatar
318
Save your $50. DIY is very simple, even this DIY-challenged person managed to do this install by himself
DIY: http://www.e90post.com/forums/showthread.php?t=17358
      10-30-2006, 01:27 PM   #13
achal
achal's Avatar
53
it says on there website...to measure u r hub centric...I hope they will fit cause..I am not gonna take a wheel off and measure....other I feel I should get 15mm..confusion...
      10-30-2006, 01:38 PM   #14
KL2DC
Moderator
KL2DC's Avatar
318
Your rear wheels are 9" ... I'd say go for the 12mm's. If you order from Rogue Engineering, they'd be sure to send you the appropriate parts. I'm very happy with their products and service.
      10-30-2006, 01:41 PM   #15
KL2DC
Moderator
KL2DC's Avatar
318
On second thought, it might be easier to go with the 15mm's. You have aftermarket wheels, not sure if they are compatible.
      10-30-2006, 03:02 PM   #16
achal
achal's Avatar
53
this is what I got
http://cgi.ebay.com/ebaymotors/ws/eB...B:EOIBSA:MT:11
u think this is OK with 12mm....or should I get 15mm....also do u want me to check both places..my shop too..how far is this place from u..cause its 1 hr. from me....
Thanx
      10-30-2006, 03:07 PM   #17
KL2DC
Moderator
KL2DC's Avatar
318
achal...I think I'd go with the 15mm for a more universal application. Not sure of those wheels' inner hub design and its compability with the 12mm spacers.
The springs install place is 15 minutes from my place...
