Smell of fuel and crazy RPM needle
02-04-2010, 12:58 PM | #1 |
Troll Harder
395
Rep 596
Drives: 997 GT3, 997 4 GTS, X6M
Hey guys
I'm hoping this isn't an HPFP problem. I went to turn on my car, and everything was fine. it took a bit of time to start, but I figured, hey it is cold.. no biggie then the car starts rumbling and shaking and my gear shift is vibrating like mad. I look at my RPM gauge and the needle is at 500RPM, I rev and I start smelling fuel, the reduced power sign comes on (half engine) I turn it off, turn it back on, this time the RPM goes up to 2,000 by itself, drops back to 500, shakes and gives me the same error. I try again, and I reverse and I see no sign of fuel but I smell it, I put it back in my spot, pop the hood, and the engine looks normal but the car is still rumbling and the RPM needle is at 500 and the engine malfunction light is still on. is it HPFP or something else?
02-04-2010, 01:42 PM | #2 |
146
Rep 1,922
Drives: E90 335i, E70 X5
scan with the BT and see what codes it is throwing... hard to tell.........
too many factors can create that problems... HPFP, injectors......
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
02-04-2010, 01:56 PM | #3 |
Troll Harder
395
Rep 596
thx for the reply
is it safe to drive? or should I tow it to the dealer? (I don't have a scanner)
02-04-2010, 02:38 PM | #4 |
105
Rep 587
Drives: 2020 M2C
I had the same thing happen to my car. In my case they had upgraded the software incorrectly (forgot to initialize adaptation values). At least mine acted up about 1 mile from the dealer so I stumbled in there.
02-04-2010, 03:38 PM | #5 |
What
141
Rep 9,325
take it to the dealer and have them check it out
E92 328xi Space Gray
Aero Lip | M3 Side Skirts | CF Performance Spoiler | ACS Roof | Gloss Black Grilles | LUX H8 Angels | BMW Performance Exhaust My E92 Photos |
02-04-2010, 03:48 PM | #6 |
Rep 79
That's the injector problem.
I had it in the beginning of the Winter. You probably saw lots of white smoke came out from the exhaust also. The car shook like it was going to stall. "Engine Service" light came up too. This problem went away after a couple of restart. The problem came more and more often every morning until the day I got my appointment to bring the car to the dealership. Eventually it injectors on one bank of the cylinders where replaced.
2014 F25 35i M Sport 2010 E90 SG M Sport - ED -> recycled 2008 E92 AW ED -> Nurburgring -> PCD -> recycled 2005 E46 Imola ZHP -> back to BMW recycle bin |
02-04-2010, 04:43 PM | #7 |
Troll Harder
395
Rep 596
I used to see a lot of white smoke
not this time though... I thought it was just normal due to my catless downpipes should I tow it or drive it there?
02-04-2010, 04:58 PM | #8 |
146
Rep 1,922
last time, well about a month ago, ALL my injectors went bad, i couldn't drive it there, once i started the car, it bogged and struggling to calm down the idle... ended up i towed mine in using BMW assist, lucky i made it back home when it happened.
-eric
02-04-2010, 09:34 PM | #10 |
Troll Harder
395
Rep 596
I'll have it towed then
thanks for the replies guys any idea how much this is going to set me back
