ZPOST
  TireRack
      02-02-2010, 08:56 AM   #1
Chris04Z4
14
Drives: 2004 Z4 Roadster 3.0i
Requesting... DIY on Vanos O-Ring replacement
read on here that these need to be replaced on pre-2005 Z4s..... looking for a DIY please!
      02-02-2010, 09:16 AM   #2
Chris04Z4
14
nevermind... DrVanos.com
Will prob just replace it with one of theirs.... through the end of Feb... $200
""Fully cleaned and rebuilt vanos unit with new seals and O-rings installed. In addition, we rebuild the internal bearings and reduce the tolerances to eliminate the 'marbles in a tin can' noises commonly found on the 'ZHP' package E46 models. The kit also includes a new vanos gasket and crush washers. Don't settle for half a rebuild, get the complete package with our dual vanos kit. "" -DrVanos.com
      02-04-2010, 01:45 PM   #3
smidley
smidley's Avatar
23
Drives: BMW E60 M5
I'm looking at doing the same replacement. Let me know how yours goes... and if you want to take some pics... that would be cool too!
      02-07-2010, 07:49 PM   #4
pokeybritches
pokeybritches's Avatar
479
Drives: ESS/G-Power Z4M, VF Z4, 996tt
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
I found this:
http://www.beisansystems.com/procedu..._procedure.htm
I also have the Vanos rattle, so I plan on doing that procedure and the spark plugs at the same time:
      02-10-2010, 12:53 AM   #5
BlackSapphireZ
97
Drives: 22 GLE 53 Coupe
for $200 its not bad, If I didn't wanna go through with the hassle I would but since I've already done it and it's not THAT bad, I would recommend just buying the seals, they are only what, $70.
just FYI, it is a B*TCH to remove the vanos unit because the front radiator support(metal bar) is in the way. It needs about 1/2" more space for it to come out. I've used a pry bar against the rad suport to move the engine a little to wiggle it out. you might dent it a little but it covers well with your well.... a rad cover.
I've done this at like 80k and it was simple following the procedure found on E46fanatics.com ALL OEM parts were bought from tischer BMW
it would be wise to do the following while you are doing this
-new valve cover and grommets(a must)
-spark plugs
-Seafoam(before, approx 100miles or less..just how I did it)
-Oil change
-water pump
-thermostat
-both fan belts
-tensioner/idler if you REALLY need it, but i have a feeling you probably won't
-I think i've made it a maintenance day and did a diff fluid change as well. I skipped the tranny because it was changed not too long ago from Dealer with OEM fluid
2022 GLE 53 Coupe
      02-14-2010, 11:42 PM   #6
smidley
smidley's Avatar
23
Drives: BMW E60 M5
Thanks for the info BlackSapphireZ!
      02-15-2010, 04:29 PM   #7
Shipkiller
Shipkiller's Avatar
187
Drives: Me
I used the Beisansystems procedures back in 2007. The entire job took about four (4) hours to complete.
zpost
