Carbon Build-up in n54 motors?
01-31-2010, 02:31 AM | #1 |
Rep 8
Hello guys, I have been wondering if the n54 motors suffer from the carbon build-up around the valves that audi fsi motors apparently suffer from? To those that have, what was the solution? Thanks
01-31-2010, 10:16 AM | #2 |
22
Rep 1,938
One hears stories about the Mercedes and Audi high pressure FI engines suffering from carbon build-up. There is no reason to assume that BMW N54 would be immune from it, but most evidence on the Internet is anecdotal, and there is little of it on this forum - most excitement has been focused on the HPFP failures. To a degree, carbon build-up can be alleviated by the composition of fuel. Lately, several fuel blends has been re-formulated, so it is possible that the carbon build-up now is less severe than that in the early FSI engines.
01-31-2010, 10:18 AM | #3 |
159
Rep 5,689
or you could use meth
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
01-31-2010, 10:32 AM | #4 |
Air India
145
Rep 1,834
use chevron fuel system cleaner every 5k miles. its quite cheap for the benefits. BMW sells this, but just a techron bottle, but seems to be relabled with bmw logo.
http://www.trademotion.com/partlocat...catalogid=4462
PKumarM3 |
01-31-2010, 10:36 AM | #5 |
84
Rep 949
This is inherent on direct injection motors as you do not have fuel running over the valves to keep them clean(er). Meth injection is one way of helping to keep them clean. You can also sea foam the motor.
01-31-2010, 10:37 AM | #6 | |
Bimmerpost Resident Marijuana Consultant
455
Rep 3,197
Drives: 320i, 325xi, 335Xi, 335i, M3
Garage List 2010 BMW 335i [0.00]
2011 BMW X335i [0.00] 2006 BMW E90 325xi [0.00] 2011 BMW E90 335xi [4.00] 2011 BMW M3 E90 [7.00] 2006 E90 320i [0.00] |
"AMG What! S-Line Who? If you ain't got that M I got no respect for you!" '06 Alpine Weiss E90 320i | '06 The Green Machine E90 325xi | '11 Alpine Weiss E90 M3 ZCP | '10 Silverstone X5M | '11 Alpine Weiss E90 335xi |
01-31-2010, 10:41 AM | #7 | |
Air India
145
Rep 1,834
i have been putting it in my 335 since 5k miles, every 5k miles, and have had no motor issues - car pulls as it did on day 1 - im at 20k miles. i have been putting this in my e46 m3 for the past 10k miles and the car is tracked often (20 times a year), and i have had no problems. i wouldn't request the dealer to put it in, unless you want to pay rape prices. just buy one, drive your car till its practically empty (let it ready in the 20s in miles remaining) , pour it into the gas tank, refill, and repeat in 5-7k miles. I would use the Chevron Techron - $7+ shipping on amazon http://www.amazon.com/Chevron-Techro.../dp/B00092893O maintenance is very important in BMWs. It will cost a few pennies now, in order to avoid a few thousands later on
PKumarM3 |
01-31-2010, 10:51 AM | #8 |
84
Rep 949
Fuel system cleaners like that (ones that go into the gas tank) will not really work as they won't flow over the valves being that we are direct injection. Sea foam the car if you want to get a cleaner across the valves - or run meth.
01-31-2010, 03:20 PM | #9 | |
158
Rep 3,158
Lots of mechanics use sea foam, on lots of vehicles. I have a can of it in my garage, and I'll be using it come spring---on my bike.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
02-01-2010, 11:52 AM | #10 |
2051
Rep 6,110
What is this "sea foam" you speak of?
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
02-01-2010, 12:01 PM | #11 |
84
Rep 949
Seafoam is a chemical that you use in 3 ways. Pour it in your oil fill (on valve cover), your gas tank, and the most useful for us --> detatch a vacuum line that goes into your intake manifold and allow the car to suck in the sea foam slowly (regulating it with your thumb over the hose to slow and speed up the ingestion) so that the car doesnt stall till the very end of the liquid. Let the car stall. Then let it sit for 15-20 minutes. Start the car up and let it idle till it gets warm-ish. Rev the car to get air flowing over the now broken down carbon deposits on your valves and watch the smoke (carbon burning off) billow out of your exhaust.
The oil fill and fuel tank aren't really needed for us. I wouldn't bother. If you are going to make sure you do it right before you change your oil because you shouldnt drive more than a few miles after you put sea foam in the oil. |
02-01-2010, 12:05 PM | #12 |
141
Rep 571
i have reported an issue with heavy carbon buildup on my 335i.
it is documented in this thread: http://www.e90post.com/forums/showthread.php?t=326116 this thread tracks a number of issues so skip to post #43 for the part about heavy carbon buildup. |
02-01-2010, 12:13 PM | #13 | |
3575
Rep 10,355
I suppose you could try disconnecting your EGR? |
02-01-2010, 12:15 PM | #14 |
The power of V!
99
Rep 1,971
Drives: 2007 335i coupe steptronic
Garage List 1998 Lexus Gs400 [0.00]
2010 ebony & ivory [0.00] 2006 BMW X3 [0.00] 2009 pics [0.00] 2009 e92 335 xdrive [0.00] |
I think it is a good ideal to get a professional fuel injection cleaning
service. I've used runrite service for my other cars http://www.run-rite.com/industry/fuel_runrite.html For the engine, nothing beats the Bilstein engine flush. http://www.redwoodgeneral.com/services/engine-flush.asp
2007 335 coupe Alpine white, steptronic, sportpack, etc. (gone)
2006 X3 3.0 steptronic Titanium Silver, 2009 E92 335xdrive, next.... Caddy CTS_V! 13 Lincoln MKZ? hmmm. |
02-01-2010, 12:40 PM | #15 |
Lord of the Rings
86
Rep 470
Drives: 20 Audi SQ5,05 BMW 330i ZHP
Garage List 2021 BMW M2C [0.00]
2020 Audi SQ5 [0.00] 2019 VW Golf Alltrack [0.00] 2018 Ford F150 [0.00] 1977 VW Scirocco [0.00] 2005 BMW 330i ZHP [0.00] 2007 Audi RS4 [0.00] |
Unless you are pulling the cleaner/solvent in through a vacuum hose, fuel additives won't clean the valves in a Direct Injected engine. Direct Injection engines spray the fuel directly into the combustion chambers and do not allow fuel (or additives, cleaners, etc) to pass across the valve.
Cheers, Chuck |
02-01-2010, 01:15 PM | #17 | |
The power of V!
99
Rep 1,971
02-01-2010, 01:21 PM | #18 |
780
Rep 2,638
..I also had my engine "de-carboned" under warranty ~Frost
M240i Coupe (6MT) (2021: 6/2021 build )
Accord Coupe (6MT) (2017) 335i Coupe (6MT) (2007: 9/06 build SOLD 8/2016) Prelude (5MT) (1995) |
02-01-2010, 01:26 PM | #19 |
640
Rep 1,716
any cost here? explain how u asked for this?
i feel like dealers would tell me to go f*ck myself, haha a lil help here ...
Formerly addicted to e46fanatics
Formerly addicted to e90post |
02-01-2010, 01:34 PM | #20 |
56
Rep 1,311
The best thing is probably to prevent it from happening by using a good Oil Catch Can and an open breather (not legal for road use)) to prevent crankcase fumes under overpressure to enter the intake. If you take a look into the Intercooler fittings and Induction Pipe there is a lot of oil heading to the intake valves Methanol aspirated engines supposedly don’t suffer from carbon built-up.
02-01-2010, 02:43 PM | #21 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
An OCC still will not catch all the crank vapors. The PCV system on the N54 has two modes, one when at idle/decel (off boost) and one when accelerating (on boost). When on boost, the vapors get diverted to the rear intake, pre-turbo since the intake manifold is pressurized (above atmosphere). This is where your OCC/breather can benefit, as it intercepts these gasses so that the Turbo/Intercooler do not get a coating of oil.
However, when off boost, the intake manifold is under vacuum, so they crank vapors get diverted directly to the intake manifold. The pcv system for this "mode" is built into the valve cover. There is nothing we can do for this unfortunately, other than installing meth. injection or periodically cleaning the valves/intake manifold with Seafoam or some other top engine cleaner. Meth/water injection would go a long way towards keeping the valves and intake manifold clean. |
02-01-2010, 04:40 PM | #22 | |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
If you are determined to use fuel additives, please, make sure you do this on the last tank of fuel BEFORE you do an oil change! You will thank me later! |
