Headlight Wiper on/off?
01-22-2010, 07:17 PM | #1 |
'15 S3 Sepang, '09 E92 Space Grey, '99 996 C2 Blk
Rep 33
Is there a way with the onboard computer to turn the headlight washers on/off, or another way? For some reason my headlight washers spray the whole hood and turn a newly clean car dirty. On my e92 it wasn't an issue at all. The washers didn't really get on the hood at all. On my e90 it makes a mess. I would like to turn it off unless I am driving in snowy / dirty conditions and manually clean them under normal driving.
I found a few functions the other day like control over the door locking mechanisms, etc. I thought it may be one of the computer options but the [my] manual doesn't have a key to many of the functions in the computer for some reason and I can't find it online? |
01-24-2010, 11:13 AM | #2 |
97
Rep 2,101
I don't think there is a way to turn them off, but they will not engage if your lights are not on. As well, if you pull the washer/wiper leaver lightly (not all the way towards you) it will only spray the windshield and not the lights.
2013 BMW 328i xDrive Sport Line Mineral Grey on Everest Grey |
01-25-2010, 10:26 AM | #3 |
Rep 98
I have to resort to turning my headlights off (if they're on) in order to not engage the headlight washers. Are you sure about pulling the wiper stalk lightly? I've tried it and it still washes my headlights... either that, or I don't have the precision of pulling it lightly enough.
01-25-2010, 01:59 PM | #4 |
Big Beaver Smile
2101
Rep 3,791
It only seems to work like that in some people's cars. I don't think that BMW intentinally made it work like that, but some people got lucky with their switches if they have the right touch.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
01-26-2010, 06:29 PM | #5 | |
97
Rep 2,101
01-26-2010, 10:56 PM | #6 |
Gearing
86
Rep 3,965
Infuriating isn't it? I have to turn my lights off or risk emptying the windshiled washer fluid prematurely. Lightly pulling the stock aint worth crap in the winter with all the baked on salt and dirt.
If at first you don't succeed ...
01-27-2010, 09:40 PM | #7 |
Rep 33
Thanks guys, I didn't know about the light trick. Good to know my ride isnt the only crakced out sprayer out there. So has anyone ever found a key to the symbols buried in the trip computer? So weird the manual doesn't explain them...I keep forgetting to ask when it is in for service.
02-10-2010, 11:09 AM | #8 |
Type A - BMW Concours Judge
19
Rep 143
There are two pumps
On my earlier 2006 320, there were two pumps attached to the washer bottle. I just disconnected the one pump which ran the headlight washer. Now, on my current 2010 328, the bottle is hidden so i am not sure how to disconnect, but maybe pull the fuse? I will check and let you know if it works.
2010 328i xDrive, Jet Black, K&N filter, Euro headlight switch, Alarm/door lock beep kit, BMS, slotted rotors with ceramic pads, etc
02-10-2010, 11:15 AM | #9 |
15
Rep 367
I believe that if you have the lights turned to the "on" position and not the "auto" position that it wont spray the headlights.....
08 Z4 3.0SI Black Sapphire/Black Int, 6sp, Sport/Premium --- retired --- 2010 BMW 650GS -- Z4 replacement Working with the most talented people on the most technically advanced automobiles.... |
02-10-2010, 08:36 PM | #10 |
Big Beaver Smile
2101
Rep 3,791
That's wrong. The position can be "auto" as well as "on". The headlights have to be illuminated at the time you pull the washer though, so if the switch is in auto, but the headlights are not on, they won't squirt. If they are lit, you'll get the squirt.
02-10-2010, 09:20 PM | #11 |
Where'd my VTEC go?
481
Rep 6,067
I believe there's a fuse you can pull which will disable them. Search for it.
