Lemon or bad luck?
01-16-2010, 01:47 AM | #1 |
Rep 69
Lemon or bad luck?
I've had the "engine failure. reduced power" error message on my 2008 E92 335xi intermittently for the past 4 months or so.
I've brought it in 3 times already: 1st time: couldn't find any problems 2nd time: told that some engine cap was loose, which they said they fixed 3rd time: told that something wrong with the injectors which they fixed. I'm still having the same problem and will taking it in again to be serviced on Monday. Do I just have bad luck or is my car a lemon? I am very frustrated. Do I have any other options at this point? Do people ever get a new car out of BMW if the same problem persists?
01-16-2010, 01:51 AM | #2 |
Prone to sudden bursts of acceleration
16
Rep 244
It's possible but i'm no mechanic,
however BMW used a plastic connector as the piece that connects the engine to the radiator or something like that, and it cracked and my engine overheated. I'd check for something with the cooling systems. If they're not finding any fault codes on the car's computer, then I wouldn't put it past the cooling systems. Your BMW engine is a pretty smart thing. Hopefully they find what's wrong, maybe you too, are affected by the HFPF I forgot what it stands for but it's pretty common with 335i's. |
01-16-2010, 07:06 AM | #3 |
Taiwanese Baller
Rep 213
i'm guessing the deal doesnt know what they're doing... and something is lose/wrong with your car and they just cant find out the reason...
my last ride...
01-16-2010, 08:38 AM | #4 |
The Logistician
69
Rep 799
Drives: 2022 230i M-Sport
Have you tried a new service department?
