Putting 6MT in R
01-14-2010, 06:34 PM | #2 |
113
Rep 1,347
Drives: 2011 335d
Fairly normal. You might have messed up the synchro mesh slightly or its just because the fluids are cold. I wouldn't worry about it unless it becomes really difficult.
01-14-2010, 06:39 PM | #3 |
23
Rep 227
Drives: 2012 328i Sportline
Double clutch
01-14-2010, 06:56 PM | #5 |
Rep 362
Put it in second, then try reverse again. should go smooth
08 328i e90 Black/Black 6MT, BMS POWER BOX, Eibach Pro System, Blacklines, M3 Spoiler, 197 BBS Wheels, Xenon and Homelink
01-14-2010, 06:58 PM | #6 |
1469
Rep 3,552
happens sometimes when its really cold to me, i usually just engage another gear then go back to R and it good.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
01-14-2010, 07:16 PM | #7 |
1274
Rep 4,703
01-14-2010, 07:19 PM | #8 |
165
Rep 7,433
+1, on other cars I've had I've had to roll forward a little bit to go backwards when it's really cold out. Didn't realize the BMWs had this "issue" too
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
01-14-2010, 07:33 PM | #9 |
Rep 166
This is what I do, works every time
2013 M3 Coupe. Interlagos Blue Metallic.
BPM Stage II, Dinan High Flow Carbon Fiber Intake, Dinan Underdrive Pulley Kit, Borla Cat-back & x-pipe. |
01-14-2010, 07:40 PM | #10 |
122
Rep 6,594
Normal.
It's not an "issue" - reverse has no synchro. Sometimes, even when stopped, you need to roll the car an inch to get it into reverse.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
01-14-2010, 07:58 PM | #12 | |
Rep 102
Manual transmissions don't have syncro's in R or 1st. To get the gears to align you must reapply the clutch or go to another gear for proper alignment.
Mods:
Dinan Stage2 Dinan Exhaust |
01-14-2010, 08:16 PM | #13 |
29
Rep 474
I always wait until I hear the flapper valve on the exhaust open up before trying to move the car and never had a problem - only takes 30-45 seconds.
01-14-2010, 08:22 PM | #14 | |
Smiling politely
165
Rep 7,931
OP just needs the fluids to warm up a bit. Try running through a few gears while the clutch is in, then put it in reverse.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
01-14-2010, 08:29 PM | #15 | |
1469
Rep 3,552
getrag supplies the MT in the 335i, here are the syncro specs: Synchronization 1st and 2nd gear triple cone 3rd and 4th gear dual cone 5th and 6th gear single cone Reverse gear single cone
01-14-2010, 09:05 PM | #16 |
Rep 102
^^^^I stand corrected. Thanks for the information.
It would seem having or not having syncros, there's still the occasional issue of neutral to 1st and R issues with this transmission. Do you have a better suggestion? My method seems to work. Now you have me curious...
Mods:
01-14-2010, 09:41 PM | #17 | |
122
Rep 6,594
01-14-2010, 10:11 PM | #18 |
70
Rep 975
This happens to me all the time. Heres what i do:
When I'm stuck and the reverse gear wont fall in, I apply slight pressure towards the direction of the R gear and slowly let out the clutch until I can feel the gear click into engagement. Then I drive off. I sounds more time consuming than it really is and I've developed a habit for doing it. If you let the clutch out too fast you'll hear grinding. I felt my changing to first or reverse gears very stiff with the colder weather recently. We've been getting mid to high 30s last week but we're in about mid 60s low 70s now. Crazy South Florida weather.
2009 BMW E90 328i | Xenons | MT | Space Gray | Beige-ette | CF Fabric Trim | iPod/USB | 20% Tints | Euro-Plate | Rear Fog Switch Lego Mod | Painted Reflectors | Performance Short-shift Kit | Style 197 Wheels | OEM Sport Suspension |
01-14-2010, 10:20 PM | #19 |
335
Rep 7,719
Putting it in first gear always fix it for me. This has also happened in my previous car, an Evo 8. And my friend experiences this also on his RSX-S.
01-15-2010, 12:44 AM | #20 | |
Rep 291
Drives: 2008 328i, with 3 pedals
Hi, Almost all modern car gearboxes have synchros in first gear. Otherwise, you'd have to be dead stopped before you can engage first. In years gone by, many didn't. My 1968 Austin Healey 3000 does not have a synchro in first and if you are rolling even a little and try to engage it, it will grind. Regards, Adnan |
