LIGHT OUT
01-14-2010, 03:10 AM | #1 |
13
Rep 136
LIGHT OUT
Need some advise PLEASEEE.
i every so once in a while get a symbol on my dash that says i got a light out, but i check all my lights and all of them work. i was told by some one that my headlights move up and down but told them it cant be it because the car comes with active headlights, idk any suggestions |
01-14-2010, 12:35 PM | #4 |
36
Rep 373
I saw a guy pull into a dealership for service because he was getting the same error message. The SA and the driver couldn't figure out which light it was, so I said check your reverse lights... and that's what it turned out to be. Just a shot in the dark.
E90 LCI by LTBMW
01-14-2010, 02:30 PM | #5 |
244
Rep 1,106
Bet you felt good! ha, I love moments like that..
01-14-2010, 04:09 PM | #7 | |
244
Rep 1,106
Funny how you individually can get more gratification helping an individual out with a dilemma, than the actual person in need gets from the solved problem! To the OP: Id try just that, throw the car in reverse! |
01-14-2010, 04:12 PM | #8 |
Go Dodgers?
93
Rep 1,557
just had my rear left light assembly replaced. I had the "light out" warning for a month before they figured it out
01-14-2010, 04:35 PM | #9 |
58
Rep 1,906
Drives: black 335i e90 PRE-LCI
you have any aftermarket lamps?... just a thought, i had an issue with the warning coming on when i changed out my plate lights, anyways good luck with the issue
01-14-2010, 07:23 PM | #10 |
165
Rep 7,433
another popular and hard to trace light is the light that comes on when you turn the wheel in the headlamp assembly
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
01-14-2010, 09:08 PM | #11 |
141
Rep 416
This doesn't have anything to do with your problem, but your headlights DO tilt up and down. They tilt when you first turn them on, and continually adjust while you're driving.
01-15-2010, 10:41 AM | #13 |
13
Rep 139
When my 'light out' message popped, it turned out to be the adaptive brake lights. The lights that are supposed to light up real bright when you stand on your brakes.
01-15-2010, 10:46 AM | #14 | |
60
Rep 2,314
I've had a light out for about a month now and just maaaaybe it is one of the reverse lights. I'm going to check tonight. |
01-15-2010, 10:48 AM | #15 |
60
Rep 2,314
01-15-2010, 11:33 AM | #16 |
Big Beaver Smile
2101
Rep 3,791
I had this the other day too. It told me "left brake light out" in my idrive, then go away and come back. When I checked the bulb, they were ALL loose. My dealer is doing the TSB (SIB 63 02 08 - all coupes before May '09) procedure Monday. OP has a coupe, so I wouldn't be surprised if this is his probem too
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
01-15-2010, 12:57 PM | #18 |
NY Yankees #1
146
Rep 1,174
Drives: 2010 AW E92
The same thing is happening to me right now but I just put in aftermarket parking lights and head lights in and I think its the parking lights(2825 LED's) I don't think its the head lights(H7's)
01-15-2010, 01:11 PM | #19 | |
31
Rep 595
01-15-2010, 01:20 PM | #20 | |
24
Rep 150
Same with me, I used the BMW wiggle technique and it went away for a week or so. I don't have iD, but I was getting CC-ID 136, "left brake light failed" During service, the dealer replaced the bulb socket to fix it. Pretty sure this is a TSB'd problem. |
