Auto Recirc?
01-13-2010, 11:45 PM | #1 |
Rep 132
Auto Recirc?
So I'm not sure if I have a problem or if this is normal, but when I select the "Auto Recirculate" function on the climate system there seem to be some odd things taking place. I'll notice the sound coming out of the system to change as if it's switching from internal to external air quite frequently. Has anyone else experienced this, or is this normal? It sort of gets loud for a few seconds then levels out, a minute or two later it does it again.
Thanks. |
01-13-2010, 11:49 PM | #2 |
Resident Black Guy
251
Rep 2,302
i dont even know what that is. but im gonna ask you. is it when you have air come on at a certain time to push out air from the car?
01-14-2010, 08:39 AM | #3 |
20
Rep 767
I have noticed it too I think ... kind of a hissing noise ? If so I guess it is normal. I used to notice it in my Jeep too but never attributed it to the auto recirculate function before this ...
01-14-2010, 09:08 AM | #4 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
Is It BEST to leave the auto recerculate button ON all the time, or leave it OFF?
Or leave it off in winter and on in summer
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i ProGaMeR on the XboX 360 |
01-14-2010, 09:12 AM | #5 |
Rep 91
01-14-2010, 09:19 AM | #6 |
Rep 175
I thought the in that mode the car "sensed" pollutants, and automatically changed to interior air, then back to exterior when the air was "good".
I tried it when I first got the car, but could not stand the constant "air flap" changing from outside to inside. Its an annoying sound change. It did react to stop and go exhaust fumes though.
wow, it's not dirty.
01-14-2010, 11:20 AM | #7 |
66
Rep 1,642
^^ thats what the manual says it does. the salesmen told me he Always leaves it on, but I dont care about pollutants as much as having it correctly work in the winter/summer
Here is what Manual says: Left-hand LED on, AUC mode: a sensor detects pollutants in the outside air. If necessary, the system blocks the supply of outside air and recirculates the inside air. As soon as the concentration of pollutants in the outside air has decreased sufficiently, the system automatically switches back to outside air supply. > Right-hand LED on, recirculated-air mode: the supply of outside air is permanently shut off. The system then recirculates the air currently within the vehicle. If condensation starts to form on the inside window surfaces during operation in the recirculated-air mode, you should switch it off while also increasing the air flow rate as required. The recirculated-air mode should not be used over an extended period of time, otherwise the air quality inside
01-14-2010, 11:35 AM | #8 | |
3572
Rep 10,352
01-14-2010, 12:45 PM | #9 |
70
Rep 975
When i was test driving the car a while back i asked the salesman where the air should be because i'd seen the same thing on my sister's car, she has the same car.
He said "You know how sometimes on long drives you can get a headache? It's because the same air in the car is recirculating and the air quality decreases." He said that it should be left on Auto because It refreshes the air in the cabin every once in a while. When i get behind a diesel truck or when i'm about to drive through a cloud of diesel exhaust, I just turn my air off.
2009 BMW E90 328i | Xenons | MT | Space Gray | Beige-ette | CF Fabric Trim | iPod/USB | 20% Tints | Euro-Plate | Rear Fog Switch Lego Mod | Painted Reflectors | Performance Short-shift Kit | Style 197 Wheels | OEM Sport Suspension |
